Loud thumping in front - Cobalt SS Network
The Lounge Off Topic PG-13. Introductions, cars, movies, work, relationships, etc.
Thread Tools Search this Thread
Old 01-11-2018, 10:27 PM   #1
Hey guys! I just got my car back and sheís making an awful thumping in the front.
It only happens when moving, itís aggressively loud and thumps the whole floor. You can feel it in the pedals, it really starts thumping past 20 and doesnít stop ever. Unless the car does. Still thumps while turning and going straight.
The car is lowered a little less then 2in.
I checked the axles, they didnít have much play in and out but I twisted the shaft to the right wheel and it moves and clunks... is that my problem? Or perhaps a bushing or balljoint.. I have no clue and I donít really know how to test this past twisting shafts and shaking ****.
i would appreciate any help. Thank you!
Williams is offline   Reply With Quote
Old 01-12-2018, 08:53 AM   #2
I haven't had an axle go bad yet so haven't experienced it but I would imagine this could be a result of a bad universal joint in your drive shaft. If you are lowered very much it binds up the U-joints more than usual. Does the thump seem to be going about the same speed as the wheels like every time you hit the same spot in the rotation it clunks? Does it stay consistent with wheel-speed regardless of which gear you are in?
jdbaugh1 is offline   Reply With Quote
Old 01-12-2018, 12:56 PM   #3
exninja's Avatar
Where did you get it back from? I would suspect a wheel is severely out-of-balance, or maybe even a destroyed hub, but that is doubtful. I think the CV joint is suspected when you have clicking noises when turning.
exninja is offline   Reply With Quote
Old 01-12-2018, 02:26 PM   #4
Quote:
I just got her back from a dyno shop. There is no clicking but itís consistent no matter which way you turn , which makes me lean away from hub bearing.. I have brand new tires on the front I suppose that could be a possibility.
Old 01-12-2018, 02:31 PM   #5
Quote:
Iím lowered 2 inches, I think. The thump is always going the same speed as the wheels and it sounds like itís one specific spot. So when that comes back around it thumps again. Gear doesnít matter at all.
Old 01-12-2018, 02:32 PM   #6
Quote:
If it only started after the tires swap I'd be suspect. Are they maybe a cheaper brand?
Next guess would be CV joint.
cluelessk is offline   Reply With Quote
Old 01-12-2018, 02:32 PM   #7
2 inches isnt enough to cause any problems
double clutch is offline   Reply With Quote
Old 01-12-2018, 02:33 PM   #8
Quote:
I didnít think so..
Old 01-12-2018, 02:37 PM   #9
Iím guessing itís a cv as well but I didnít want to leap into it. The tires are BFGs comps so there shouldnít be a problem with them unless they have a spot or the shop didnít balance them. I donít quite remember when it started to make the noise. It wasnít this significant when I last used the car daily, I know that. But itís also been sitting for months getting new this and new thats.
Old 01-12-2018, 02:52 PM   #10
I would rotate the fronts to the back just to be sure its not the issue, before you start digging deeper.
Thread Thread Starter Forum Replies Last Post
Thumping noise on passenger side devon9832 Suspension 2 08-19-2009 07:05 AM
Thumping Thursday Workchat 4-23-09 Cobalt_1988 The Lounge 339 04-23-2009 10:35 PM
Loud thumping when turning BlackSapper Suspension 6 04-17-2009 03:38 AM
Thumping noise? cobaltSS2.4liter General Cobalt 13 02-25-2008 10:19 PM
how loud is LOUD? BlwnGP 2.4L LE5 Performance Tech 17 02-23-2007 11:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
