Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   New Members Check In!! (https://www.cobaltss.net/forums/new-members-check-186/)
-   -   06 Supercharged Tips? (https://www.cobaltss.net/forums/new-members-check-186/06-supercharged-tips-319039/)
medic710 Sep 6, 2015 01:20 PM
Hello everyone, new to cobalts picked up a 2006 supercharged with the following alleged upgrades:
Dyno Tuned via ZZP (275hp)
2.9" Supercharger Pulley
"Bigger" Injectors (sigh)
Cold air intake w/ K&N
ZZP Shorty Header
ZZP Downpipe w/ High Flow Cat
ZZP Rotated Trans mounts
New struts/shocks
Powell VV3 Lowering Springs
New Control Arms / Moog Components
New Timing Chain / Balance Shaft Chain
New Guides / Tensioner / Bolts / Gaskets
New Thermostat
Vehicle has 79k miles. I have not seen boost above 15, and at idle -15, feels a little sluggish like it could use a tune up but runs sound. Advice? Cheap easy improvement ideas? Any red flags? And also what spark plugs would you guys recommend? Thanks!
double clutch Sep 6, 2015 08:53 PM
Use ngk plugs. Go one step colder than stock. Im not sure on the part number. Do a little searching and youll find it on here. Clean your k&n filter. Check to make sure your intercooler pump is running. I think all you have to do with a zzp tune is turn the key into the on position and it should kick on.
