New here and need some help
3 Attachment(s)
I recently purchased a HHR SS. I am in the process of replacing the head gasket. Almost done but I have a ground wire that lost the tag I marked it with and I don't know where it should hook up to. It is in the area of the high pressure fuel pump. It could connect under the intake manifold as well.
The end of the wire connects to other ground wires in the front driver's side of the engine compartment. BTW - tons of great information on this forum - I have gained knowledge from many posts. I attached 3 photos showing the connections 1. showing a closeup of the connection I need to find a home for. 2. showing where the wire connects 3. the general location of the wire |
what year and ill get a ground location diagram, vin works best if you can get that
It is a 2009 HHR
3GNCA63X59S500898 I do have a repair manual with wiring diagrams, I can certainly look through and see if I can find the connection. *slapping my head for not thinking of that* |
https://cimg9.ibsrv.net/gimg/www.cob...744f2622a8.png
there is four grounds, looking to see if there is anymore, one under the alternator and another under the oil cooler on the trans. the two top right is by the fuse block |
https://cimg9.ibsrv.net/gimg/www.cob...2c9c2fe5a7.png
heres one on the backside attached to the corner of the cyl head |
https://cimg1.ibsrv.net/gimg/www.cob...5bda62b9a0.png
there is another view of the one under the cooler(#2) and alternator(#4). |
https://cimg4.ibsrv.net/gimg/www.cob...7e783fb8dc.png
last one I can find that goes behind the left headlamp on the upper radiator support bar Hope those help |
Originally Posted by Kolt
(Post 7680982)
there is four grounds, looking to see if there is anymore, one under the alternator and another under the oil cooler on the trans. the two top right is by the fuse block This image is perfect My lost connection is #3 Many thanks |
