can i use nitrous with cruise ??
quick simple question, can i use nitrous hif i have cruise control ??
Not sure what you mean if you have "cruise control". Any Nitrous kit engages & sprays upon full throttle, at which point if your cruise control is active, it will disengage. Does that help?
http://www.imglols.com/wp-content/ma...g-Not-Sure.jpg
I mean come on lets think about this logically. . . . cruise controll is used to maintain a steady speed, nitrous is used to increase it. If your asking if you can have both physically equipped, yes. The fact your asking this means you shouldn't use it. |
no i mean, where do i install the activation switch hif my throttle switch is electronic ?? theres no cable running from the gaz peddal to the throttle body
Trying to think of an appropriate response here...
1 shiny rotor 3 not, part 2?
Originally Posted by All In 360
(Post 5706410)
(Post 5706410)
Originally Posted by CLCHNGO
(Post 5706413)
hahaha cmon.. dont be so harsh haha
finaly i found my own answer,
That means you have to fabricate a mounting bracket for the switch and adjust the placement of the switch to make it work right. Our nitrous kit utilizes a wire that you simply clip on the throttle position sensor (TPS) output voltage wire. The TPS voltage signal is sent to a programmable electronic switch that engages and disengages the system at a predetermined voltage threshold. Above the threshold determined for wide open throttle, the system activates. Below the voltage threshold, it remains dormant. |
(Post 5706410)
Ask a stupid question...
