e85 + nitrous = ?
e85 + nitrous = ?
Does anyone know if you can run e85 with a wet kit? im looking into converting to e85 in the next few weeks but i have no idea if i can still run my nitrous or not. Any info would help.
You can run nitrous with just about anything. I use N2O to burn polypropolene plastic fuel
in Hi-Powered model rockets with hybrid rocket motors.
N2O is an oxidizer meaning it promotes combustion through
the addition of oxygen. Your jetting is totally different when you use different fuels, for
instance with ethanol race fuel will need 20 to 40 % bigger fuel jets I don't know what you would need for E85 but as a rule start rich then lean up to find the right set up.
Macgyver2484
09-02-2015 05:44 PM
