Want to know wat shot to run a stock SS/SC
I've run up to a 90 shot on a stock motor with adjusted timing to keep it safe, a 50 shot will be fine on basically any setup with no adjustments unless you have a radical tune with heavily advanced timing already. Nitrous won't fix any problems, but it sure will make them show up if they are already there. If your setup is safe and consistent now, a little nitrous is a great way to make power.
Anything under Stage 2, I'd say a 75 shot would be the max without tuning for it. Once the car sees more boost and timing, you should run a smaller shot (50) unless you are going for a new tune.
can someone post a link to a good website that sells the No2 kits...i got a 06' ss/sc stage 2.. and i see you guys say a 50 shot would do well but would a 75 be a bad idea?
camaromanss1992
10-01-2015 10:51 PM
