Ryan's Garage
Alright I'm going to keep this spot as a build thread for my car. Also to show off, some of the stuff I do on a regular basis :)
My Ion has changed quite a bit since I was driving it in the summer. I didn't even take pictures of it last summer, because I was un-happy with it. last summer mods list CA front mount heat exchanger Pacesetter header "custom" Catless downpipe (that I hate) Meth injection LS4 Throttle body with custom spacer Custom Intake (stupid design) AEM UEGO HP tuned (terribly) 60 lb/hr injectors Return fuel system 35 shot nitrous 2.9 pulley Spec Lightweight flywheel Spec stg 2+ clutch I had a lot of issue's with HPT flashing my car, it kept throwing communication codes and what not, and I could not figure out why. I tried everything I could, everything tested fine but still no luck with HP tuners. I dyno'd 238whp 218wtrq off nitrous (pegging my wideband at 10:1 AFR :lol:) 266whp 236wtrq with nitrous I was fortunate enough to be able to keep my car in the garage all winter because I got a winter beater for cheap. This is how it looked before last monday (the hood was put on a few weeks ago) http://i647.photobucket.com/albums/u...e/DSC_0816.jpg I have also spent quite a bit of money on the car, to get it to the point of where I will be happy with it. Now since it starting to warm up, I can finally start getting the car ready for spring. First off, body work I drilled the rivets out of the license plate holder, because I hate the front license where it was. Well this obviously left holes that were just as ugly. So I filled them http://i647.photobucket.com/albums/u...e/DSC_0818.jpg http://i647.photobucket.com/albums/u...e/DSC_0819.jpg Obviously started with removing the bumper http://i647.photobucket.com/albums/u...e/DSC_0822.jpg I used a plastic filler bought from Welle Auto Parts I forgot to take pictures using it. Required a lot of sanding. This is how it sits as of right now http://i647.photobucket.com/albums/u...e/DSC_0278.jpg Holes filled, sanded and ready for paint. Next I started on my hood. The hood was used, and damaged in shipping. I personally do not like the full carbon fiber look of the hood, and decided the sides would be painted to match the car. Here's the damage http://i647.photobucket.com/albums/u...e/DSC_0820.jpg I started with grinding the damage off each side and beveling the edge for better bondage (lol) http://i647.photobucket.com/albums/u...e/DSC_0285.jpg http://i647.photobucket.com/albums/u...e/DSC_0286.jpg Then since the area was so small that was damaged and not a structural part, I just used fiberglass enforced filler. Built up the corners http://i647.photobucket.com/albums/u...e/DSC_0290.jpg Then I shaped the corners with my grinder http://i647.photobucket.com/albums/u...e/DSC_0291.jpg and sanded and primed everything http://i647.photobucket.com/albums/u...e/DSC_0296.jpg And this is how it sits as of now. Everything will be painted either this weekend or next weekend. (don't mind my friends finger lol) http://i647.photobucket.com/albums/u...e/DSC_0303.jpg I have a lot of work to do on this damn car in the coming weeks. Including putting these on http://i647.photobucket.com/albums/u...e/DSC_0824.jpg To do list (this month lol) Paint Pull my gas tank and figure out my fuel issue (explained later) Finish fabbing my new intake system Re-wire Meth injection Remove my trans to replace the clutch actuator Re-make my CF front lip More pictures will be added as things come around |
off to a great start!
I like those MSR rims, what size are they?
They are 17x7 +35 offset..
Bought from Jason @ Aplusperformance, very good guy to work with. Highly recommended |
Wheels are on..
http://i647.photobucket.com/albums/u.../DSC_08212.jpg http://i647.photobucket.com/albums/u.../DSC_08222.jpg http://i647.photobucket.com/albums/u.../DSC_08232.jpg http://i647.photobucket.com/albums/u.../DSC_08242.jpg Painted has been delayed until this weekend, the person painting it had some other work that needed to be finished first. I am hoping I figured out my fuel issue. I removed the fuel tank, replaced my fuel pump sock with a new one, re-did my fuel line under the car. Turns outs I had a evap leak, that I knew about, but might be the culprit to my tuning woe's I have had. The car would be extremely rich when my gas tank is full, and extremely lean when the gas tank would get below 1/2 tank of gas. Unfortunately I didn't get any pictures of this I did however make a new bracket for my Aeromotive FPR. My old one was literally falling apart (poor buildmanship lol) but the new one is 100000x better old http://i647.photobucket.com/albums/u.../DSC_02772.jpg New http://i647.photobucket.com/albums/u...SC_08182-1.jpg |
Those look great on a rl.
