head gasket blown
head gasket blown
Just curious before i go digging in to replace this.... can i do this with avoiding the timing chain? I can't find any how to's.
Well been doing some research and found out once you start putting some good power into these engines the head bolts tend to stretch in the end having the head float and that's why the gasket leaks..... i just ordered a gasket but the ARP studs are pretty expensive.... hopefully it will work. *praying*
well i do know the studs are a weak point with the LSJ but with your mods i don't think it would be an issue yet. I know most of the people who put now near or over 300 whp get the ARP ones. but i don't know about replacing the head gasket you probably will have to deal with the timing chain atleast i know Tom did when he worked on his head and crap.
How cheap? LMAO i'm supposed to be driving this thing down to AZ on thursday.... and about the timing i would love to get your help Tom. I just ordered a cometic gasket and lsj build book... thinking about ordering the head studs and possibly headwork if it's cheap?
Well it's sitting for about a week. Started it up this morning and light grey smoke.... let it run awhile and it mostly went away but still visible. Pulled my dipstick and saw a feint line of milk. Very hard to see though. Do you need to drain your oil and radiator to remove head?
as for the cam gear bolts they are about 23$ for the pair
other then that you will need to add coolant (alot will come out) and change your oil afterwards
they say you also need to replace your cam gear bolt (has to come out to do this) in order to do it right
confirm this is DEF the problem before pulling it apart
for the coolant you just drain what you can out of the head before taking it off and then the rest in the head will fall out upon removal, just clean it up and you are good, then just fill to full when reassmbling
not alot, you just about made sure with the mily oil lol, you could try an oil change to see if it is just something else in the oil..but prob not
does it run fine? do you feel compression out the dipstick when the car runs?
we can do a compression test as well
How much is the compression tool or you have one? and it runs fine but tiny stumble every once in awhile maybe? hard to tell. i will check the dipstick thing real quick....
Yeah me to keep buying more and more tools.... i'ma need to get whatever socket it is to take the head off to..... i didn't notice any blowing/sucking from the dipstick.....
Oh and my last oil change i noticed a lil milk on my oil filler cap. wiped off and stayed clean... there's not much milky i've seen but definetly is some. car isn't pumpin alot of smoke like it was when i first started it though.... thing this could be fixed later or can cause a big problem at anytime?
are you having to add coolant at all???
nope hasn't dropped at all
And these headstuds? You need though plus the other 10 long ones and 4 shorties? is that right?
OK cool thanks gunna go buy the tool and test
oh so the ARP are all 14?
you take out all sparks for test?
Test Results! This bad? sounds pretty off to me?
142 - 125 - 125 - 120
Think i may go test that first one again.
60$ after tax for a mill (resurfacing) and wash in auburn at the same place i did it
your supposed to do each cyl 3 times and average, and let it crank for 5 sec and then let the guge settle out before reading it
http://www.youtube.com/watch?v=-snWFtBdrsY
<object width="660" height="525"><param name="movie" value="http://www.youtube.com/v/-snWFtBdrsY&hl=en&fs=1&color1=0x3a3a3a&color2=0x999 999&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-snWFtBdrsY&hl=en&fs=1&color1=0x3a3a3a&color2=0x999 999&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>
