SC and TB ported & polished (no 56k)
I did a mild port on the supercharger and throttle body. I took a 1/4" off the outlet of the SC. I opened the inlet a little more than 1/8" and sanded the hell out of it (it was rough cast in there). I also matched the throttle body to the inlet of the SC and sanded down all the harsh edges in there. I've seen that a lot of people doing this and going big. I just wanted to get 1/4" into it to see how much more response I get. After all, I can take more off, but I can't add any once it's gone, so let the testing begin! Here are some pics of the project, enjoy!
https://www.cobaltss.net/gallery/fil...2/P1010010.JPG "The Beginning" https://www.cobaltss.net/gallery/fil...2/P1010022.JPG Cover up that hole. https://www.cobaltss.net/gallery/fil...2/P1010026.JPG Before the porting. https://www.cobaltss.net/gallery/fil...2/P1010106.JPG Cover them bearings, shavings are gonna fly! https://www.cobaltss.net/gallery/fil...2/P1010112.JPG After the porting, still needs a little clean up work. https://www.cobaltss.net/gallery/fil...2/P1010107.JPG Polishing the outside too! https://www.cobaltss.net/gallery/fil...2/P1010114.JPG MY FINGERS HURT LIKE A MO-FO AFTER THIS PROJECT!!! https://www.cobaltss.net/gallery/fil...2/P1010116.JPG I had to do something with the TB. I wasn't going to atempt to polish it. I liked the lines it had on it so I did this to make it look better. https://www.cobaltss.net/gallery/fil...2/P1010117.JPG Another angle. https://www.cobaltss.net/gallery/fil...2/P1010118.JPG Last one. The pics didn't come out that good of the inside of the TB or the inlet of the SC so I didn't post them. Sorry, my camera sucks ass! |
looks awesome, i feel for your fingers, i did all for of my stock rims........never again!
Looks good!
What did you use to polish everything? I see some steel wool in the pics...Did you do it all by hand? ! |
oh its so sexy :D
sexy!
I did most of it by hand. I used sand paper 60 grit all the way up to 2000 grit, steel wool and Mothers Billet Polish. I did use a dremmel and die grinder but most places they would not fit.
Looks Great I do have to say from seeing the T/B on friday to now I do like how you sanded off some of the black paint on it. How much did you hone out your T/B?
Well, I got it on and it sounds really good. I haven't driven my car in a while so I can't really tell the difference. It does seem a bit more responsive and it's definitely louder. I didn't get a chance to do any launches yet though. I will tomorrow definitely, that should be the test to tell if It did any good.
Originally Posted by 06' SS2SS
(Post 996971)
I matched it to the inlet of the SC and took off about 1/4" and sanded down all the harsh edges in there so air would flow a bit better.
Looks good though! Try to take pics of the inside. I would like to see how you did this |
Originally Posted by TxLonghorn#1
I tried the same thing ^ and now my car sits at idle bad and the rpm's jump up and down bad too! I had to order another throttle body.
Looks good though! Try to take pics of the inside. I would like to see how you did this __________________ |
