2.5 inch downpipe and exhaust for LSJ
Hey guys, looking for a 2.5 inch down pipe and cutback exhaust for my LSJ.
As for the down pipe, I'd prefer ZZP but open to all offers. It MUST be catted and MUST have an extra o2 bung. MUST be 2.5 inch as the title says. As for the exhaust, I'd also prefer ZZP but open to other offers as well. Thanks! Edit: also looking for a set of coil overs. Possibly even 2 sets of coil overs for both of my LSJs. |
Don't waste your time with a 2.5" downpipe on the LSJ fyi....
I have a 3 inch now, it's too much for the stock supercharger
Originally Posted by Chris06CobaltSS
(Post 7623829)
The stock downpipe is 2.75". Leave the 3" downpipe on there. |
(Post 7623916)
No it's not....
(Post 7623929)
It necks down to like 2.25" at the o2 sensor.
The dimple at the o2 sensor is not 2.25"... it is simply dimpled. Yes there is a reduction in cross sectional area of the pipe there, but the majority of the piping is 2.75" with a 2.375" outlet. Regardless of this, the OP should stick with his 3" downpipe. I've tested all sorts of downpipes on my car. The zzp 2.5" downpipe is a mess. Terrible transition from the flex to the cat. Their 3" downpipe was made much better. |
I feel like I'm losing power because of the down pipe and exhaust though. Stock pulley, stock everything
Stock everything? Put a stock down pipe on and be done with it (until the flex breaks lol)
(Post 7623979)
The bigger exhaust moves the torque curve a bit higher due to being more efficent. If you switch back to smaller exhaust, you actually restrict the engine at higher rpms so it "feels" stronger down low. Put a 3" pulley on there and a set of GM stage kit injectors, it will pick up all that low end you lost and then some, plus gain 40hp up top. |
I have 80 injectors. I'm going turbo this winter and I have most of the kit. The cobalt isn't my daily driver and I miss driving it. The cat on my 3 inch down pipe is done for I believe, so just to get the car running again I was considering going back to a 2.5 inch dp and exhaust. When I'm turbo I'm running 3 inch catless
(Post 7623931)
I dissected a stock SS/SC downpipe back in the day.
Originally Posted by Ecotecftw
(Post 7624015)
Thanks for the info. This helped me with some questions I had.
I have Vibrant high-flo header, catless downpipe, magnaflow muffler, was straight piped between but put a resonator back on. Willing to go full stock if someone wants to trade everything.
06 LSJ |
Originally Posted by ujustgotshook713
(Post 7624192)
I have Vibrant high-flo header, catless downpipe, magnaflow muffler, was straight piped between but put a resonator back on. Willing to go full stock if someone wants to trade everything. 06 LSJ
