For Sale F35 5 speed Transmission- 4.45 gears
$1250.00- F35 5 speed Transmission- 4.45 gears rebuilt byJohn Powell. Trans has approximately 10,000 miles on it since rebuild. It is inexcellent shape with no issues. I do not beat on my car. The transmission wasthoroughly cleaned and painted by me. Every nook and cranny was cleaned before applyingHi Temp primer and paint. I am selling this because I have since installed theF40 6 speed in my Cobalt. This transmission does not come with a speed sensorbecause I am using it in my 6 speed. Other than that it is ready to go!
ZZP 6 speed conversion. Quaife LSD. This is probably the best upgrades I did besides the ZFR. So nice to drive. Very smooth. I totally recommend if you have the bucks. If not the 4.45 5 speed is good.
@ Snail. I’d definitely do the LSD. Very easy install. I did mine. I did have to use a different shim during setup. I have a lot of info and pics for my F40 if you need.
shipping is separate. Looks to be approximately $190 to your location. I have a nice wooden box that I built for the transmission when I shipped it to Powell two years ago. The 4.45 gears are very sought after for F35 I paid $700 for the gears alone. Powell went through the trans and said it was in excellent shape. My bill from Powell was $2100 plus I paid shipping. It only has approximately 10,000 easy miles on it. Besides needing the speed sensor it’s readt to install and go. I am in no hurry to sell. If money is an issue than you could probably find another 4.05 geared F35 a lot cheaper.
So, I want this bad. I have massive gear whine in all gears; cruising, accel and deaccel. BRUTAL. From what I gather, this could be preload on the final drive, whining trans output shaft bearings, intermediate shaft, etc. It's mega loud and can be heard over the radio at 2/3 volume. I'm trans shopping because I'm under the impression it's in the trans and not something I can just fix myself without replacement.
Is this trans loud? I'd hate to get it only to be as loud as my current trans. Also, I'm in NY and can pay cash and pick it up if need be.
I had absolutely no issue with noise. No whining at all. I used the South Bend Stage 4 clutch and stock flywheel with the trans which is listed for sale as well. RPM’ s are up on the highway cruise but it’s doable. 3k at 70mph.
Also, how much for the SB St4 clutch and flywheel? Stock flywheel is the LNF flywheel yes? The LSJ one works too and is much cheaper, but is 2 lbs heavier. Any savings if purchased all together
Chanyeezy
03-03-2018 12:06 AM
