Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Parts (https://www.cobaltss.net/forums/parts-66/)
-   -   Wanted Throttle Body Harness (https://www.cobaltss.net/forums/parts-66/throttle-body-harness-262347/)
Allgood Customs Sep 30, 2011 06:49 PM
Hey guys, I bought the 06 throttle body with a 8 pin. I have an 08 with an 6 pin. I need to get a harness/adapter that I can connect two together with, or someone to swap with. Let me know
Thanks
Allgood Customs Sep 30, 2011 08:06 PM
...BuMp
chevygirl2006 Sep 30, 2011 08:07 PM
i have a harness from a 2.4 throttle body
Allgood Customs Oct 4, 2011 12:48 AM
Still in need
Allgood Customs Oct 4, 2011 09:25 PM
even a link to one would help :D
drumrush Oct 4, 2011 11:56 PM
Pin D (Purple): TP Sensor 2 Signal
Pin E (Yellow): TAC Motor control 1
Pin F (Brown): TAC Motor control 2
Pin G (Gray): 5-Volt Ref 1
Pin H (Black/White): Low Reference
6-Pin
Pin A (Brown): TAC Motor control 2
Pin B (Yellow): TAC Motor control 1
Pin C (Tan): Low Reference
Pin D (Dark Green): TP Sensor 1 Signal
Pin E (Gray): 5-Volt Reference
Pin F (Purple): TP Sensor 2 Signal
8-Pin >>> 6 Pin
A > D (Dark Green)
B > E (Gray)
C > C (Tan)
D > F (Purple)
E > B (Yellow)
F > A (Brown)
G > E (Gray)
H > C (Tan)
B/G both go to Pin E (Gray)
C/H both go to Pin C (Tan)
theres a diagram i guess you could say showing how to rewire it... just in case you would consider it
Allgood Customs Oct 5, 2011 11:17 PM
well how do I get 6 pins to 8 pins
drumrush Oct 5, 2011 11:18 PM
zzp will well you an 8 pin harness for like 30 bucks, then just rewire it using the above diagram
