07 lsj-t problems gen 3 build
Okay so ive been having this problem for about 2 weeks now. I start the car and idles for about 4 seconds then dies like if its choking/sputtering. i have checked fuses, fuel pressure, compression, fuel filter, spark plugs, vacuum leaks, maf, fuel pump, throttle body, map, and everything in between. Also if i start the car and give it gas it wont die on me but only as long as i give it gas. I can drive it around but i jave to constantly be giving it gas. What could it be? i cant figure it out. And i sure the tune is not the problem as its being tuned by alan. Any ideas or thoughts? Please let me knw:/
That's a tough answer with the info given. Throttle body perhaps.
I swapped out the throttle body 2 times with working ones from two cars. Im using an le5 2.4 throttle body on a saab manifold if that makes a difference. also swapped mafs and map sensors and still same problem. It doesnt even throw a code other than random misfire and ac pressure switch which i wired to monitor a/f ratio.
vacuum leak
Originally Posted by Adiaz1ss
(Post 7567011)
| All times are GMT -4. The time now is 12:26 AM. |
