(2.2l) Excessive oil leaking from valve cover pcv
Had a breather filter on there and it was saturated with oil. I got a new intake with an actual hose I took it off to look at it and the whole intake and everything is soaked with oil. What m might be wrong? Thanks.
Go any Check Engine Light on by any chance?
Hot air coming from the breather tube/oil cap is normal, hence the fact its called a "breather" tube lol.
Maybe you did have too much oil at one point and that's why oil is in your outlet induct (filter in your case), just clean it out, keep an eye on your oil levels and your cleaned filter and see what happens, some oil will always come through the breather tube, so small amounts is normal, no worries there.
So my final advice is this: catch cans fix nothing and if the people that use this sort of thing havent had any problems in years it doesnt mean u wont have so fix it!!! lol Cleaning your throttle body every month is a bitch...
lol 2 years late wow u may still be able to save ur car !! hahaha
Last edited by yosaya; 02-06-2014 at 12:54 PM. Reason: didnt notice the year the thread originally started lol
ThoR294
10-04-2015 08:44 PM
