2006, SS, 2.4, oil leak above starter below intake
anyone have this issue? it leaks oil in that spot, cant see even up in air, unless i take things off like, starter, intake, and lord knows what else...any ideas before i tear into it? i ask as i read on here how to remove inner door panel when door wouldnt open and i had success...thanks
Mark
Mark
You have 2 places where it can be leaking there.
Oil Pressure switch. Most likely!
Crank Sensor.
I have my engine apart so their easy to get to from above but you would be better off pulling the starter.
If you wanted to put some black light engine oil dye in it and run it a while, it should show up quickly.
Crank Sensor.
oclaf (12-11-2017)
Diaz1488
02-10-2014 04:30 PM
wordsthatiwrote
08-29-2007 02:53 AM
