2009 Turbo Misfire Code wont erase
Okay, so I didnt let the SS warm up enough when I leaned into it in 2nd gear. Immediatly the Car bogged down and misfires at 6800 RPM. My MIL flashes for a bout 3-5 secs and then turns solid and has been on since.
The next day I had a friend who had an old Equus 3030 (The very very basic obd2 diag. tool) scan the codes. Out pops p0300,p0303, p0304 and p0300 p0303, p0304. Same codes repeated 2x.
We tried to reset the MIL using the Equus 3030 but the lamp simply stayed on and when the Equus says that the MIL has been reset and we restart the motor, the codes flash back again. (Now I understand the MIL would come back on if my cylinders 3 and 4 were to misfire again, but the MIL never went off in the first place)
My car performance wise is stock except for the Trifecta Tune.
Is it because the Equus is running on old firmware that I cannot delete these codes properly? or Is it something else? Should I just disconnect the battery for 10 mins?
Sorry for a bit of a noob question.
Thanks in advance
Thanks in advance
I hate to be the first to tell you that you've likely caused engine damage in the order of one destroyed ring land. And since GM is on the prowl for non-factory ECM tunes...an astute tech is gonna find it and your warranty will be voided.
With all this said, pull your spark plugs, it is POSSIBLE you chunked a bit of one off and it safely exited your engine, but with a turbo in the way of a clean break, not likely. Again, sorry bro. All signs point to engine detonation.
EDIT
I wanted to add this.
P0300- Random Misfire
P0303- Cylinder 3 Misfire
P0304- Cylinder 4 Misfire
Gut would tell me you popped a head gasket, but these motors blow pistons before gaskets, any chance you can post a youtube vid of your engine idling maybe some revs under light boost?
EDIT
EDIT
EDIT
well if he did a NLS then its not bad cause it happens to mine... plus vince recommends not to NLS with his tune anyways. however if you did it while NLS then just clear the codes by going to autozone or somewhere then u should be fine. i dont think theres anything wrong.
Hey guys, I wasnt NLSing when it misfired. Not running the Infiniboost either. The car runs exactly the same way as it did before the misfire happend, so I dont think I could of done any huge damage, who knows.
The car is now at the local dealer and getting the codes read n possible repairs done. When I was there they had their gm scanner on the vehicle already. By the time I left, they had the car pulled into the bay and no one mentioned anything about my tune so Im hoping they will overlook it somehow.
Thanks for the response, I'll keep you guys updated.
