bluebaltjim |
05-29-2009 06:50 PM |
50 amp fuse by battery blown
so i'm coming home this afternoon and the car just dies out of nowhere, im about 1/4 mile from my house so it's not too bad. the dash had power but when you turn the key the starter wouldn't even try to engage. it turned out to be the 50 amp fuse on the negative battery cable in the trunk. i wouldn't have even thought to check there but i made a quick call to CJ Krause who did my trifecta tune for me, and he suggested i check there. replaced the fuse and everything worked, he also suggested i open the fuse tray in the engine compartment and check that they're all secure in their connections as well. several of those fuses were only partially pushed in so possibly that was the cause of the large fuse in the trunk blowing. if anyone has had this problem and has found another cause post your findings. i'll be going over the entire car this weekend looking for loose connections and any sign of faults in the wire loom.
