ABS light problems?
Old Jul 15, 2008 | 12:15 AM
dervin3's Avatar
ABS light problems?
Man long time since I been here. Used to be on here regularly but with a new wife and baby on the way well I've been very busy Anyways onto my problem. I have an '05 SS S/C and my ABS light comes on. Sometimes very frequently. If I turn off the car and restart it goes away. I've noticed it always comes on when I hit a bump, no matter how small or large. Even dips in the road will do it. I'm no expert on brakes but what kind of sensors or wires could be getting tugged at to cause my ABS light to come on? I really don't have the money right now to take it anyway and was hoping to diagnose this myself. Any info is much appreciated!
Old Jul 15, 2008 | 04:10 PM
JayB1127's Avatar
Ive been having a similar problem only the TCS light comes on as well.......Took it to the dealrship this morning and turned out to be a loose wire in the Left front fender well. Just my input, becase your TCS light isnt comeing on it might be a different problem.
Jay B
Old Jul 18, 2008 | 04:45 AM
dervin3's Avatar
I'm just trying to diagnose the problem without going to the shop if it's a simple fix. I checked the fluid level and it was a bit low so I topped it off and on the ride back home it didn't come on. Typically it will as I turn onto my street as its uphill and real bumpy. I've got my fingers crossed but I expect it to just return tommorow eventually. What other things can I check for without going to the shop?
Old Jul 18, 2008 | 04:58 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I have an 05 with 55,000 miles... my ABS light has been on constantly ever since 52,000 miles.
I think that a sensor has just gone bad. And I don't think that there is a Cheap Fix.
Old Jul 18, 2008 | 08:35 PM
hubes's Avatar
you could check all electrical connections including wheel speed sensors, according to my haynes manual it says check fluid level and electrical connections, if that doesnt fix it take it to the dealer
Old Jul 18, 2008 | 09:45 PM
tiny's Avatar
I had the same thing, but it's on almost all the time now
i have 30k, my warranty ran out
i would like to avoid the dealer as well, if you get any ideas please let me know
Old Jul 18, 2008 | 09:50 PM
joeworkstoohard's Avatar
you have more than a 30k warranty.
mine does it sometimes too. about once every 6 months. i just unhook the battery for 10, and it goes out. usually, it's just a wheel speed sensor, they're like, $50
Old Jul 21, 2008 | 11:23 PM
tiny's Avatar
you're right, it's a 3 year warranty. it ran out in april, so I have no warranty left...
Old Aug 2, 2008 | 03:29 AM
Murdered SS's Avatar
i have the same problem it just started a couple days ago but do u think if i take it to the dealer the warranty will cover that and i also have an exhaust leek does anyone know if thats covered
Old Aug 2, 2008 | 04:09 PM
dervin3's Avatar
I just went to the dealer this past week and as it turns out is a bad hub and bearing causing the ABS system to throw code C0045 I believe is the code. Code read something like irratic signal coming from that wheel. Anyways I'm set up to have it repaired this thursday and I hope it will last until then. Hell the ABS light has been coming on for like 3 months or so and I haven't noticed it get any worse. There is a slight tug to one side and a squeek in the wheel at slow speed but I was just assuming worn brake pads. Anyways, glad to have a diagnosis and anyone else with ABS light issues might wanna get it checked ASAP maybe your hub and/or bearing has gone bad to.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
