Corroded Fuel Line Leaks
Hey all,
I'm a "new" member here, but I've been a long time viewer for over 10 years; this forum has a ton of great contributors and a library's worth of information. I have seen a number of threads in which members have experienced fuel leaks due to the metallurgy of the fuel lines between the fuel tank and fuel rail/HPFP; of course the overwhelming majority of affected vehicles are in the Northeast and Midwest. The leak occurs at the section of fuel line within the plastic brackets in the driver's side rear fender well, and it seems that most members have either repaired it themselves or had the dealer/shop patch in new lines. My '08 SS experienced this issue in 2015 around 70,000 miles; fuel was pouring all over the ground in the dead of winter. I had to travel cross country for a new job, so I made do by patching in a new line with a compression fitting - less than ideal. Since buying this car I've had it in the air more than a few times for maintenance, and I always assumed the bare fuel lines were stainless; clearly that is not the case.
With this being a serious safety issue and an involved/expensive repair, I reported the issue to NHTSA (today actually, finally got around to it) so that I can add my case to the reports. As this involves a fuel leak (potential fire), these cases are prioritized by NHTSA, so it takes a smaller amount of reports to issue a recall than other (less pertinent) reported issues. Once it's on NHTSA's radar, they will investigate GM's internal reports to gather additional information.
I encourage everyone on here who has experienced this issue to file a NHTSA claim, regardless of whether is was covered under warranty, you fixed it yourself, or you paid out of pocket. If NHTSA gets even just a few more reports, than can request a recall from GM to repair all affected vehicles, which includes reimbursing customers who paid the dealer to fix their vehicle. I'll post the link below:
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
I just ordered a complete line kit from FineLine (Part # FL255-A1D) to replace the patch job I had to do on my car. The kit is complete from fuel tank to fuel rail, includes the filter, and comes in 4 sections with union fittings for easier installation. The lines are also coated so they won't rust through like the original lines. If a recall is then issued, I'll apply for reimbursement from GM.
Had this happen on my 06 Cobalt and my daughter's 04 Ion. I just spliced in new lines with compression fittings and no issues since! I would be happy to file a complaint as well. That insulating wrap they put around the fuel lines sure like to hold salt and moisture!
Sport Red LNF (11-12-2018)
Mine are rusted, been keeping a eye on them. Hopefully gm does issue a extended coverage or recall. All vehicle should be using either stainless lines for fuel imo.
