BPS and TPS SES Codes- Need some help.
I'm looking at picking up a 2006 SS/SC that's been around the block a time or two.
It's currently throwing 3 codes, P0121, P0128, and P2229
I was planning on replacing the Coolant Sensor, Throttle Position Sensor, and Barometric Pressure Sensor.
The coolant sensor code is typically just a sensor failure on every car I've experienced a failure on. I ain't even worried.
The TPS sensor code: Is the TPS integrated into the Throttle Body? I can't find an independent sensor...
The BPS Code: Is the BPS called the MAP at the parts stores? I don't have a manual and I normally don't mess with these cars. I would expect purely from the name that the BPS is the MAP.
Thanks in advance folks
TPS is part of the throttle body. Must replace the whole unit.
That's good info. I couldn't find it easily using the forum search function. I hate that the TPS is integrated. That's a PITA.
He has an LSJ. It's fairly easier.
Take intake off.
Unplug throttle body connecter underneath
disconect evap hose on front of throttle body
remove the 4 10mm bolts that hold the throttlebody on
then reverse process
Take intake off.
twilson380
Sep 14, 2015 10:52 AM
