BPS and TPS SES Codes- Need some help.
Old Jan 11, 2015 | 12:55 PM
OMGWTFBODY's Avatar
Question BPS and TPS SES Codes- Need some help.
I'm looking at picking up a 2006 SS/SC that's been around the block a time or two.
It's currently throwing 3 codes, P0121, P0128, and P2229
I was planning on replacing the Coolant Sensor, Throttle Position Sensor, and Barometric Pressure Sensor.
The coolant sensor code is typically just a sensor failure on every car I've experienced a failure on. I ain't even worried.
The TPS sensor code: Is the TPS integrated into the Throttle Body? I can't find an independent sensor...
The BPS Code: Is the BPS called the MAP at the parts stores? I don't have a manual and I normally don't mess with these cars. I would expect purely from the name that the BPS is the MAP.
Thanks in advance folks
Old Jan 11, 2015 | 01:06 PM
TStone's Avatar
Baro sensor is separate from the MAP. Baro is a 3 wire sensor and MAP is a 4 wire because it also has iat2 in it. It is sometimes referred to as a TMAP (temperature and map).
TPS is part of the throttle body. Must replace the whole unit.
Old Jan 11, 2015 | 01:11 PM
OMGWTFBODY's Avatar
That's good info. I couldn't find it easily using the forum search function. I hate that the TPS is integrated. That's a PITA.
Old Jan 11, 2015 | 01:32 PM
Yeah the tps sucks to change or well the whole TB. Im my tc I removed the manifold to remove it took me like 40 mins to install
Old Jan 11, 2015 | 01:50 PM
TStone's Avatar
He has an LSJ. It's fairly easier.
Take intake off.
Unplug throttle body connecter underneath
disconect evap hose on front of throttle body
remove the 4 10mm bolts that hold the throttlebody on
then reverse process
Old Jan 11, 2015 | 02:02 PM
Lol good for him
Old Jan 11, 2015 | 02:07 PM
OMGWTFBODY's Avatar
I'm just looking for a cheap and slow DD. =D
Old Jan 11, 2015 | 08:49 PM
exninja's Avatar
It's pretty easy from below...
Old Jan 11, 2015 | 09:09 PM
Well it is if you have a good jacks or a lift lol but now i can do it in no time
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
twilson380
Sep 14, 2015 10:52 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
