Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   Can a cam or valves squeal ? PLEASE HELP! (https://www.cobaltss.net/forums/problems-service-maintenance-69/can-cam-valves-squeal-please-help-207480/)
Joefish Mar 10, 2010 08:01 PM
In a 2.2 L ecotec in a grand am, has anyone ever heard of a high pitched squeak coming from the cam shafts/valves and or head area. There is also excessive valve ticking noise. This problem has caused the engine to stall on 2 occasions. It restarted no problem, but i am afraid to drive it.
I listened with a stethoscope and it sounded like the squeallinfg was coming from the exhust side of the head, maybe the above the number 2 and 3 cylinders.
I noticed some build up/crud on the cam lobe directly under the oil fill cap, but the edges of the lobe were ok, just the middle was bad-looking.
I did a retorque on the camshaft caps with no improvements.
reddevil Mar 11, 2010 07:01 AM
The squeak could be an exhaust leak.. Post a good pic of cam..
