Can't get the Key out
I have a slight problem. I drive a 2.4 and its auto. My problem is that every time I go some were and put it in park I go to turn off the car and It wont let me take the key out. I have to push up on the shifter hard and then I can some times get the key out anyone know what the problem could be? I really don't want to take it to a dealer because I have alot of extra stuff Iv done to the car.
yep common problem on the cobalts..bring it to the dealer..they will fix that problem
Originally Posted by iLLmaTic3s
(Post 2470301)
its a sensor on the right side of the shift assembly, its a cheap design and when the bracket breaks it will not let the bar return to its original position. when it doesnt return it shows that the vehicle is not in park and will not release the key
and what we would do is, remove the top cover. pull the 4 13mm bolts holding it down, releast the shift cable and walla! its out |
this happened to me. its the shifter linkage. it gets worn out, they will have to replace the entire shifter assembly.
This happend to my HHR. i lived with it. i just traded it in for a cobalt.
Push toward crank and then try to get it out worked for me. btw i couldnt over crank my HHR dont know about auto balts. |
Originally Posted by xfemannuel
(Post 2472668)
this happend to me when i first got my car an kinda jerry riged all my electronics up. Once i totally redid everything the right way my key stoped getting stuck... idk if this will help you...
all the dealership will do is replace the shifter assembly. and it will be ok.
Originally Posted by jeremie
(Post 2472695)
yep, new shifter assembly....bad BTSI
there's a spot under the steering column that you can jam a small screwdriver into to release the key...I believe it's a white plastic piece...you'll have to remove the cover first |
| All times are GMT -4. The time now is 04:55 AM. |
