car keeps goin into limp mode
alright... this is a long story...i have a 2.0 ss/sc and i haven't done anything different to the car in a long time... last thing was the exhaust and that was 2 months ago... cars been fine for the longest time... i decided to hit the highway and when getting on the highway i redlined second.... no different then i do every now and then... no issues i start to shift to get to fifth and after about a minute of driving the car goes into limp mode... P0068 and P0121 r on... i clear them and drive back home... next day i take everything apart... intake and tb come out.... i clean the cone... clean the intake pipes.... clean the tb.... wipe off my MAF... wipe off my MAP... look inside my charger... everythings clean... wile my cone dries i inspect my couplings and all that... everything seems good... inside my charger it looks kinda dirty... i rubbed my finger in it and it was kinda gunky... looked like carbon buildup... same like on a tb... not sure if thats normal or not... but anyway i put everything back together better then it was originally and still get codes... this time P0068, P0121, P2228.... so i take out the MAP and test it and it seems to be getting a reading... i didn't have a gauge to use so i don't know if it was accurate but it did read something when i tested it... so i think thats fine... i let it sit for a day and decided to try to drive it... everything was good... no codes... no limp... i park it... eat dinner... get back in to go out with the gf... limp mode again... this time P0068, P0069, P0121, P2228... and i noticed that my rpm was reving up and down on its own... up to about 1500 and as low as 500 then back to about 800 again... so i parked the car and haven't touched it since... any idea's? tb? tps? maf? map?
DTC
DTC Descriptor Module That Sets the DTC Diagnostic Procedure P0068 Throttle Body Airflow Performance ECM, PCM • DTC P0068 for the 2.0L engine • DTC P0068 for the 2.2L (L61) engine • DTC P0068 or P0121 for the 2.4L engine P0069 Manifold Absolute Pressure - Barometric Pressure Correlation PCM DTC P0069 P0121 Throttle Position (TP) Sensor 1 Performance ECM, PCM • DTC P0121 for the 2.0L engine • DTC P0121 for the 2.2L (L61) engine • DTC P0068 or P0121 for the 2.4L engine P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage PCM DTC P2228 |
Check your barometer pressure sensor and scip sensor connectors and wiring for damage..
(Take a good close look using a magnifying glass if you have one.) May have been damaged by who ever changed your oil or they didnt clip the connectors on positively. I noticed when changing the oil filter there is alot of interference with the connectors in that area even if your careful with a extension. |
Originally Posted by Coblasts
(Post 4241297)
The scip is on the supercharger and the baro is behind it which would be the one you disconnect when you change the oil but not a 100 % on that one.
(Post 4241991)
thew on a new tb today to try and see if that changed anything... only threw 2 codes this time... still went limp... P0068 and P0069
