Car shaking under WOT
Old 05-13-2008, 09:45 PM
cobaltBlackss's Avatar
I did a few hours of tuning last night and I was getting very close to nailing my AFR...then it happened. During a 2-3 pull, after i shifted into 3rd, at 5 thousand rpms my front end started shaking, almost like my engine was moving back and forth. So I tried it again and same thing over 4 thousand rpms the car shakes. I checked all of my mounts (including the driver side tranny mount) and they all seem intact. I torqued down my lug nuts and tried again. Same result. During normal driving the bumping is non-existant even up to 100mph. Once I go WOT it happens. The rpm and speed climb like normal it just shakes like hell. WTF?
Recent mods: Larger throttle body, coilovers.
Old 05-13-2008, 09:48 PM
Xenozx's Avatar
Id have to say it might have something to do w/ the coil overs. As far as what I have no idea, but its definately not normal. Maybe you need to tighten your engine mounts, as at WOT your stressing too much, and messing something up.
Im only guessing, Im sure someone else probably knows better
Old 05-13-2008, 09:50 PM
Red2.4SS's Avatar
Coil pack(s) bad?
Spark plugs fouled?
Old 05-13-2008, 09:53 PM
I checked my log and the spark seems right, just like the rpm. I don't think it is engine related, but I hav been proven wrong before.
Old 05-13-2008, 09:54 PM
JERMzSS's Avatar
Mine has a slight vibration in 1st and 2nd ever since I lowered it. But its fine the rest of the time.
Old 05-14-2008, 12:07 AM
The coilovers have been in for about two weeks now, this is all of a sudden. Any other suggestions?
Last edited by cobaltBlackss; 05-14-2008 at 12:07 AM. Reason: Automerged Doublepost
Old 05-14-2008, 08:33 AM
Coblasts's Avatar
Heres a few guesses for you.
clutch chattering.
Slipping under load slightly and grabbing again.
Bad cv joint(axel)
You wouldnt be getting wheel hop would you ?
Old 05-14-2008, 05:30 PM
Nope no wheel hop. I took it to the dealer today and it's my sycro's.
Old 05-18-2008, 03:23 PM
Problem not solved, even after a new transmission. Has anyone's wheel speed sensor gone out before?
Old 05-18-2008, 11:23 PM
Coblasts's Avatar
One plus
A new tranny !
Im still going with a bad Cv joint.
When mine went on my other car, I could accelerate slowly but any harder and the car felt like someone was using a jackhammer on it.
Old 05-18-2008, 11:27 PM
D4u2s0t's Avatar
i would also say cv joint. you'll only notice it on hard acceleration, it will go away when you're coasting, and won't be noticeable on slow acceleration. if those are the symptoms, i can almost guarantee that's what it is. a good test for this is get rolling, put the car into 4th or 5th (at a low speed, maybe like 30mph) and hit the gas. this will put alot of load on the car, and if it shakes like a **** that's a good sign that the cv joint is shot.
Old 05-19-2008, 01:21 PM
^^^ thanks for the input guys, those are my exact symptoms. The shity part is that I have the upgraded half shafts so I'll have to get it sent off once they figure out which cv joint it is.
Old 05-20-2008, 06:34 PM
update, I'm getting p0325 now (knock sensor circuit.
Old 05-20-2008, 06:44 PM
WopOnTour's Avatar
The vibration might have set that...
I would have a compression test and leak-down done since it's only when you are under power
Doesnt sound good
WOT
Turbo Johnny
02-21-2019 09:41 AM
turboecotec02
11-26-2015 10:43 AM
chefhhr
10-26-2015 10:36 PM
hawkssoccer11
09-30-2015 12:14 PM
SS_2009_TC
09-04-2015 10:48 AM
Quick Reply: Car shaking under WOT
