Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   Car shut off. Sounds way different now (https://www.cobaltss.net/forums/problems-service-maintenance-69/car-shut-off-sounds-way-different-now-326350/)
rdmason May 29, 2018 11:24 AM
So I was on the highway and I floored my car in second and hit rev limiter and it shut off. Ever since that the car is very quiet compared to what I Was before and the supercharger sounds way different. Any ideas? I can’t really tell a loss in power or anything
07blackg5 May 29, 2018 11:45 AM
Are you mechanically inclined? Pull the valve cover and see if you dropped a rocker. It's fairly common in these engines with rev limiter related mishaps, and will cause the car to sound choked or muffled.
When you say the blower sounds different, what do you mean exactly?
rdmason May 29, 2018 11:57 AM
yeah I can do that I’ll check later. The blower just has a deeper whine and doesn’t sound right and there’s kind of a whistle to It almost
07blackg5 May 29, 2018 01:42 PM
While you have the valve cover off, it would be a good time to check that the timing chain guides are in tact, and replace your chain tensioner if it has never been done, depending on mileage.
Slowbalt2000 May 29, 2018 02:44 PM
If you lost a rocker arm, some might say it makes the car "rumble" or sound like a subaru. Is this the case?
