Catless
I am catless and I have not deleted code from my ecu but i dont get any codes. Could i get my car inspected in NY with out having that code deleted even though there is no HIstory for a catless code. They just plug it in a scan, them looking at it is no biggey.
thanks mike |
it will come up sooner or later
Depends on which of the readiness monitors the state accepts and how many are allowed to fail. In PA you can have one readiness monitor fail and still pass the emmissions portion of the state inspection.
Even if you set the HO2 so the check engine light does not come on it will be picked up by their scanner. |
Originally Posted by Mike08ss/tc
(Post 5651940)
thanks mike |
Originally Posted by northvibe
(Post 5653725)
you have a cel but dont get a cel? I guess I'm confused here. If they put a sniffer sensor thing on yoru exhaust they will notice right away you dont have a cat. depends on what the test for etc.
If it passes the look test you should be good haha
Just go to a buddy that has a shop and you will be fine ------lick and stick----- :lol: |
Originally Posted by Supercharged Guy
(Post 5653864)
if you dont have a cel and they only scan then you should be fine. Now if you had a cel previously and have not cleared it from your pcm history, you should do that before hand.
(Post 5653887)
who did your tune? just get them to shut it off and you wont have to worry
Originally Posted by elecblue06
(Post 5654595)
