The Cobalt DTC thread (merged)
Old 07-07-2005, 07:42 PM
WopOnTour's Avatar
Here is a complete list of ALL POSSIBLE DTCs that can be present in a 2005 Cobalt SS/SC (w/ LSJ) and the modules in whch the DTC may be stored.
Enjoy
WopOnTour
DTC DTC Description -Module/s That Sets the DTC
B0012 Driver Frontal Deployment Loop Stage 1 -SDM
B0013 Driver Frontal Deployment Loop Stage 2 -SDM
B0015 Left Front Seat Belt Pretensioner Deployment Loop -SDM
B0016 Left Roof Rail Deployment Loop -SDM
B0019 Passenger Frontal Deployment Loop Stage 1 -SDM
B0020 Passenger Frontal Deployment Loop Stage 2 -SDM
B0022 Right Front Seat Belt Pretensioner Deployment Loop -SDM
B0023 Right Roof Rail Deployment Loop -SDM
B0052 Deployment Commanded -SDM
B0053 Deployment Commanded with Loop DTCs present -SDM
B0055 Side Air Bag Deployment Commanded -SDM
B0083 Front End Sensor 1 -SDM
B0085 LF/Driver Side Impact Sensor -SDM
B0086 RF/Passenger Side Impact Sensor -SDM
B0158 Outside Air Temperature Sensor -HVAC
B0285 Electric Rear Defrost Circuit Low -BCM
B1000 Electronic Control Unit (ECU) Performance -BCM, DRR, IPV, Radio, SDM, VCIM
B1001 Option Configuration Error -DRR, Radio, SDM
B1004 Keep Alive Memory (KAM) Reset -BCM, DRR, IPC
B1009 EEPROM Checksum Mismatch -BCM, Radio
B1019 System Configuration Error -SDM
B1025 LF Audio Output Circuit -Radio
B1035 RF Audio Output Circuit -Radio
B1045 LR Audio Output Circuit -Radio
B1055 RR Audio Output Circuit -Radio
B1325 Device Power 1 Circuit -BCM, IPC, Radio, SDM
B1370 Device Ignition 1 Circuit -BCM, SDM
B1380 Device Ignition ACCESSORY Circuit -BCM
B1441 Device Ignition OFF, RUN, and CRANK Circuit -BCM
B1480 Battery Rundown Protection Circuit -BCM
B1516 Battery Current Sensor Performance -BCM
B1517 Battery Voltage -IPM
B2455 Cellular Phone Microphone Circuit Malfunction -VCIM
B2470 Cellular Phone Antenna Circuit Malfunction -VCIM
B2476 Cellular Phone Select Service Switch Malfunction (3-button assembly) -VCIM
B2482 Cellular Phone Select Switch Range/Performance -VCIM
B2483 GPS Sensor Circuit Low -VCIM
B2484 GPS Sensor Circuit Open -VCIM
B2530 Front Fog Lamps Control Circuit -BCM
B2580 Headlamp High Beam Control Circuit -BCM
B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit -BCM
B2645 Ambient Light Sensor Circuit -BCM
B2705 Gearshift Unlock Circuit -BCM
B2750 Horn Relay Output -BCM
B2955 Security System Sensor Data Circuit -BCM
B2960 Security System Sensor Data Incorrect but Valid -BCM
B2961 Key In Ignition Circuit -BCM
B3031 Security System Controller In Learn Mode -BCM
B3033 Security System Indicates Tamper -BCM
B3100 X Link Programming/Diagnostic mode acknowledge message not received -BCM
B3109 Keyless Entry Transmitter Low Battery -BCM
B3127 Left Front/Driver Door Only Unlock Circuit Low -BCM
B3132 All Door Unlock Circuit Low -BCM
B3137 All Door Lock Circuit Low -BCM
B3265 Trunk Relay Output -BCM
B3715 Front Wiper Relay Drive Circuit -BCM
B3716 Front Wiper Relay Drive Circuit Range/Performance -BCM
B3717 Front Wiper Relay Drive Circuit Low -BCM
B3718 Front Wiper Relay Drive Circuit High -BCM
B3719 Front Wiper Relay Drive Circuit Open -BCM
B3794 Cruise Control Function Request Circuit -BCM
B3903 Stop Lamp Relay Circuit -BCM
B3948 Left Front Turn Signal Circuit -BCM
B3949 Right Front Turn Signal Circuit -BCM
B3950 Left Rear Turn Signal Circuit -BCM
B3951 Right Rear Turn Signal Circuit -BCM
C0000 Vehicle Speed Information Circuit -PSCM
C0035 LF Wheel Speed Sensor Circuit -EBCM
C0040 RF Wheel Speed Sensor Circuit -EBCM
C0045 LR Wheel Speed Sensor Circuit -EBCM
C0050 RR Wheel Speed Sensor Circuit -EBCM
C0110 Pump Motor Circuit -EBCM
C0116 Pump Motor Relay Circuit -EBCM
C0121 Valve Relay Circuit -EBCM
C0161 ABS/TCS Brake Switch Circuit -EBCM
C0176 System Thermal Error -PSCM
C0220 Left Front ABS Channel in Release Too Long -EBCM
C0221 Right Front ABS Channel in Release Too Long -EBCM
C0228 Left Rear ABS Channel in Release Too Long -EBCM
C0229 Right Rear ABS Channel in Release Too Long -EBCM
C0240 PCM Traction Control Not Allowed -EBCM
C0242 PCM Indicated TCS Malfunction -EBCM
C0281 Dynamic Rear Proportioning (DRP) Performance -EBCM
C0475 Electric Steering Motor Circuit -PSCM
C0545 Steering Wheel Torque Input Sensor -PSCM
C0550 Electronic Control Unit (ECU) Performance -EBCM
C0552 Improper Shutdown -EBCM
C0561 System Disabled Information Stored -EBCM
C0845 Device Ignition 1 Circuit -PSCM
C0895 Device Voltage -PSCM
C0899 Device Voltage Low -EBCM
C0900 Device Voltage High -EBCM
P0030 HO2S Heater Control Circuit Sensor 1 -PCM
P0033 Supercharger Bypass Valve Solenoid Control Circuit -PCM
P0036 HO2S Heater Control Circuit Sensor 2 -PCM
P0068 Throttle Body Airflow Performance -PCM
P0069 Supercharger Inlet Pressure (SCIP) - Barometric (BARO) Pressure Correlation -PCM
P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage -PCM
P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage -PCM
P0101 Mass Air Flow (MAF) Sensor Performance - PCM
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency -PCM
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency -PCM
P0106 Manifold Absolute Pressure (MAP) Sensor Performance -PCM
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage -PCM
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage -PCM
P0112 Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage -PCM
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage -PCM
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage -PCM
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage -PCM
P0120 Throttle Position (TP) Sensor 1 Circuit -PCM
P0121 Throttle Position (TP) Sensor 1 Performance -PCM
P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage -PCM
P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage -PCM
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control -PCM
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating -PCM
P0130 HO2S Circuit Sensor 1 -PCM
P0131 HO2S Circuit Low Voltage Sensor 1 -PCM
P0132 HO2S Circuit High Voltage Sensor 1 -PCM
P0133 HO2S Slow Response Sensor 1 -PCM
P0134 HO2S Circuit Insufficient Activity Sensor 1 -PCM
P0135 HO2S Heater Performance Sensor 1 -PCM
P0136 HO2S Circuit Sensor 2 -PCM
P0137 HO2S Circuit Low Voltage Sensor 2 -PCM
P0138 HO2S Circuit High Voltage Sensor 2 -PCM
P0140 HO2S Circuit Insufficient Activity Sensor 2 -PCM
P0141 HO2S Heater Performance Sensor 2 -PCM
P0171 Fuel Trim System Lean -PCM
P0172 Fuel Trim System Rich -PCM
P0201 Injector 1 Control Circuit -PCM
P0202 Injector 2 Control Circuit -PCM
P0203 Injector 3 Control Circuit -PCM
P0204 Injector 4 Control Circuit -PCM
P0220 Throttle Position (TP) Sensor 2 Circuit -PCM
P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage -PCM
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage -PCM
P0230 Fuel Pump Relay Control Circuit -PCM
P023A Charge Air Cooler (CAC) Coolant Pump Relay Control Circuit -PCM
P0300 Engine Misfire Detected -PCM
P0301 Cylinder 1 Misfire Detected -PCM
P0302 Cylinder 2 Misfire Detected -PCM
P0303 Cylinder 3 Misfire Detected -PCM
P0304 Cylinder 4 Misfire Detected -PCM
P0315 Crankshaft Position (CKP) System Variation Not Learned -PCM
P0325 Knock Sensor (KS) Circuit -PCM
P0326 Knock Sensor (KS) Performance -PCM
P0327 Knock Sensor (KS) Circuit Low Voltage -PCM
P0335 Crankshaft Position (CKP) Sensor Circuit -PCM
P0336 Crankshaft Position (CKP) Sensor Performance -PCM
P0340 Camshaft Position (CMP) Sensor Circuit -PCM
P0341 Camshaft Position (CMP) Sensor Performance -PCM
P0351 Ignition Coil 1 Control Circuit -PCM
P0352 Ignition Coil 2 Control Circuit -PCM
P0353 Ignition Coil 3 Control Circuit -PCM
P0354 Ignition Coil 4 Control Circuit -PCM
P0420 Catalyst System Low Efficiency -PCM
P0442 Evaporative Emission (EVAP) System Small Leak Detected -ECM, PCM
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit -PCM
P0446 Evaporative Emission (EVAP) Vent System Performance -PCM
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit -PCM
P0451 Fuel Tank Pressure (FTP) Sensor Performance -PCM
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage -PCM
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage -PCM
P0454 Fuel Tank Pressure (FTP) Sensor Circuit Intermittent -PCM
P0455 Evaporative Emission (EVAP) System Large Leak Detected -PCM
P0461 Fuel Level Sensor Performance -PCM
P0462 Fuel Level Sensor Circuit Low Voltage -PCM
P0463 Fuel Level Sensor Circuit High Voltage -PCM
P0480 Cooling Fan Relay 1 Control Circuit -PCM
P0481 Cooling Fan Relay 2 Control Circuit -PCM
P0482 Cooling Fan Relay 3 Control Circuit -PCM
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge -PCM
P0502 Vehicle Speed Sensor (VSS) Circuit Low Voltage -PCM
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent -PCM
P0506 Idle Speed Low -PCM
P0507 Idle Speed High -PCM
P0520 Engine Oil Pressure (EOP) Sensor Circuit -PCM
P0532 (A/C) Air Conditioning Pressure Sensor Circuit Low Voltage -PCM
P0533 (A/C) Air Conditioning Pressure Sensor Circuit High Voltage -PCM
P0562 System Voltage Low -PCM
P0563 System Voltage High -PCM
P0601 Control Module Read Only Memory (ROM) -PCM
P0602 Control Module Not Programmed -PCM
P0603 Control Module Long Term Memory Reset -PCM
P0604 Control Module Random Access Memory (RAM) -PCM
P0605 Control Module Programming Read Only Memory (ROM) -PCM
P0606 Control Module Internal Performance -PCM
P0607 Control Module Performance -PCM
P060E Control Module Throttle Position (TP) System Performance -PCM
P0621 Generator L-Terminal Circuit -PCM
P0622 Generator F-Terminal Circuit -PCM
P0641 5-Volt Reference 1 Circuit -PCM
P0650 Malfunction Indicator Lamp (MIL) Control Circuit -PCM
P0651 5-Volt Reference 2 Circuit -PCM
P0719 Brake Switch Circuit Low Voltage -PCM
P0724 Brake Switch Circuit High Voltage -PCM
P0833 Clutch Pedal Switch 2 Circuit -PCM
P1101 Intake Air Flow System Performance -PCM
P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage -PCM
P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage -PCM
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage -PCM
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage -PCM
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage -PCM
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage -PCM
P1133 HO2S Insufficient Switching Sensor 1 -PCM
P1182 Supercharger Inlet Pressure Sensor Performance -PCM
P1183 Supercharger Inlet Pressure Sensor Circuit Low Voltage -PCM
P1184 Supercharger Inlet Pressure Sensor Circuit High Voltage -PCM
P1258 Engine Coolant Over Temperature - Fuel Disabled -PCM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance -PCM
P1574 Stop Lamp Switch Circuit -PCM
P1600 Control Module Long Term Memory Reset -PCM
P1621 Control Module Long Term Memory Performance -PCM
P1626 Theft Deterrent Fuel Enable Signal Lost -PCM
P1627 Control Module Analog to Digital Performance -PCM
P1630 Theft Deterrent Learn Mode Active -PCM
P1631 Theft Deterrent Start Enable Signal Not Correct -PCM
P1633 Ignition 0 Switch Circuit -PCM
P1680 Control Module Accelerator Pedal Position (APP) System Performance -PCM
P1681 Control Module Throttle Position (TP) System Performance -PCM
P1682 Ignition 1 Switch Circuit 2 -PCM
P1683 Control Module Ignition Off Timer Performance -PCM
P1700 Transmission Control Module (TCM) Requested MIL Illumination -PCM
P2101 Throttle Actuator Position Performance -PCM
P2119 Throttle Closed Position Performance -PCM
P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit -PCM
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage -PCM
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage -PCM
P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit -PCM
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage -PCM
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage -PCM
P2135 Throttle Position (TP) Sensor 1-2 Correlation -PCM
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation -PCM
P2176 Minimum Throttle Position Not Learned -PCM
P2227 Barometric Pressure (BARO) Sensor Performance -PCM
P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage -PCM
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage -PCM
P2535 Ignition 1 Switch Circuit High Voltage -PCM
P2610 Control Module Ignition Off Timer Performance -PCM
U0001 High Speed CAN Communication Bus -PCM
U1300 Class 2 Data Link Low -PCM
U1301 Class 2 Data Link High -PCM
U1305 Class 2 Data Link Low or High -PCM
U1500 Inter-Device Dedicated Bus Malfunction -VCIM
U2100 Controller Area Network (CAN) Bus Communication -BCM, EBCM, IPC, PCM, PSCM, Radio, SDM,VCIM
U2103 Fewer Controllers On Bus Than Programmed -IPC, Radio, SDM, VCIM
U2105 Lost Communications with Engine Control System -BCM, EBCM, PSCM
U2106 Lost Communications with Transmission Control System -BCM, EBCM, PSCM
U2107 Lost Communications with Body Control System -EBCM, IPC, PCM
U2108 Lost Communications with ABS/TCS Control System -BCM
U2109 Lost Communications with Powertrain Multiple Control System -EBCM, PSCM
U2111 Lost Communications with Steering Control System -BCM
U2113 Lost Communications with Sensing Diagnostic Module (SDM) -BCM
U2116 Lost Communications with Instrument Panel Cluster (IPC) -BCM, PSCM
U2125 Lost Communications with Mobile Communications Control Systems -BCM
B- Body System DTCs
C- Chassis System DTCs
P- Powertrain System DTCs
U- Network System DTCs
BCM - Body Control Module
EBCM - Electronic Brake Control Module
IPC - Instrument Panel Cluster
PCM - Powertrain Control Module
PSCM - Power Steering Control Module
SDM - Sensing Diagnostic Module (airbags)
VCIM - Vehicle Communication Interface Module (OnStar)
Old 01-29-2006, 10:11 PM
WopOnTour's Avatar
DTC List- 2006 Cobalt (All)
DTC# DTC Description - Module/s That Sets the DTC
B0015 Left Front Seat Belt Pretensioner Deployment - SDM
B0016 Left Roof Rail Deployment Loop SDM
B0019 Passenger Frontal Deployment Loop Stage 1 SDM
B0020 Passenger Frontal Deployment Loop Stage 2 SDM
B0022 Right Front Seat Belt Pretensioner Deployment SDM
B0023 Right Roof Rail Deployment Loop SDM
B0052 Deployment Commanded SDM
B0053 Deployment Commanded with Loop DTCs present SDM
B0081 Passenger Presence System SDM
B0083 Front End Sensor SDM
B0085 Left Front Side Impact Sensor SDM
B0086 Right Front Side Impact Sensor SDM
B0158 Outside Air Temperature Sensor BCM HVAC
B0285 Electric Rear Defrost Circuit Low BCM
B1000 Electronic Control Unit (ECU) Performance- BCM, DRR, IPC, Radio, SDM, VCIM
B1001 Option Configuration Error BCM, DRR, Radio,SDM,VCIM
B1004 Electronic Control Unit Identification Circuit BCM, DRR, IPC
B1009 EEPROM Checksum Mismatch BCM, Radio
B1019 System Configuration Error SDM
B1025 LF Audio Output Circuit Radio
B1035 RF Audio Output Circuit Radio
B1045 LR Audio Output Circuit Radio
B1055 RR Audio Output Circuit Radio
B1325 Device Power 1 Circuit BCM, IPC, Radio, SDM
B1370 Device Ignition 1 Circuit BCM, SDM
B1380 Device Ignition ACCESSORY Circuit- BCM
B1441 Device Ignition OFF, RUN, and CRANK Circuit- BCM
B1480 Battery Rundown Protection Circuit BCM
B1516 Battery Current Sensor Performance BCM
B1517 Battery Voltage BCM
B2455 Cellular Phone Microphone Circuit Malfunction VCIM
B2470 Cellular Phone Antenna Circuit Malfunction VCIM
B2476 Cellular Phone Select Service Switch Malfunction VCIM
B2482 Cellular Phone Select Switch Range/Performance VCIM
B2483 GPS Sensor Circuit Low VCIM
B2484 GPS Sensor Circuit Open VCIM
B2530 Front Fog Lamps Control Circuit BCM
B2580 Headlamp High Beam Control Circuit BCM
B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit BCM
B2645 Ambient Light Sensor Circuit BCM
B2705 Gearshift Unlock Circuit BCM
B2750 Horn Relay Coil Circuit BCM
B2961 Key In Ignition Circuit - BCM
B3031 Security System Controller In Learn Mode BCM
B3055 No Transponder Modulation or No Transponder BCM
B3060 Unprogrammed Transponder Identification Code Received BCM
B3100 Keyless Entry Data Link Circuit BCM
B3109 Keyless Entry Transmitter Low Battery BCM
B3127 Left Front Door Only Unlock Circuit Low BCM
B3132 All Door Unlock Circuit Low BCM
B3137 All Door Lock Circuit Low BCM
B3265 Trunk Release Output Circuit BCM
B3715 Front Wiper Relay Drive Circuit BCM
B3716 Front Wiper Relay Drive Circuit Range/Performance BCM
B3717 Front Wiper Relay Drive Circuit Low BCM
B3718 Front Wiper Relay Drive Circuit High BCM
B3719 Front Wiper Relay Drive Circuit Open BCM
B3794 Cruise Control Function Request Circuit BCM
B3903 Stop Lamp Relay Circuit BCM
B3935 Transponder Authentication Error BCM
B3948 Left Front Turn Signal Circuit BCM
B3949 Right Front Turn Signal Circuit BCM
B3950 Left Rear Turn Signal Circuit BCM
B3951 Right Rear Turn Signal Circuit BCM
B3976 Unconfigured Transponder BCM
C0000 Vehicle Speed Information Circuit - PSCM
C0035 LF Wheel Speed Sensor Circuit EBCM
C0040 RF Wheel Speed Sensor Circuit EBCM
C0045 LR Wheel Speed Sensor Circuit EBCM
C0050 RR Wheel Speed Sensor Circuit EBCM
C0110 Pump Motor Circuit EBCM
C0116 Pump Motor Relay Circuit EBCM
C0121 Valve Relay Circuit EBCM
C0161 ABS/TCS Brake Switch Circuit EBCM
C0176 System Thermal Error PSCM
C0220 Left Front ABS Channel in Release Too Long EBCM
C0221 Right Front ABS Channel in Release Too Long EBCM
C0228 Left Rear ABS Channel in Release Too Long EBCM
C0229 Right Rear ABS Channel in Release Too Long EBCM
C0240 PCM Traction Control Not Allowed EBCM
C0242 PCM Indicated TCS Malfunction EBCM
C0281 Dynamic Rear Proportioning (DRP) Performance EBCM
C0475 Electric Steering Motor Circuit PSCM
C0545 Steering Wheel Torque Input Sensor PSCM
C0550 Electronic Control Unit (ECU) Performance EBCM
C0552 Improper Shutdown EBCM
C0561 System Disabled Information Stored EBCM
C0845 Device Ignition 1 Circuit PSCM
C0895 Device Voltage PSCM
C0899 Device Voltage Low EBCM
C0900 Device Voltage High EBCM
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit ECM
P0011 Intake Camshaft Position (CMP) System Performance ECM
P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit ECM
P0014 Exhaust Camshaft Position (CMP) System Performance ECM
P0016 Crankshaft Position (CKP) - Intake Camshaft Position (CMP) Correlation- ECM
P0017 Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation - ECM, PCM
P0030 HO2S Heater Control Circuit Sensor 1 ECM, PCM
P0033 Supercharger Bypass Valve Solenoid Control Circuit PCM
P0036 HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0053 HO2S Heater Resistance Sensor 1 ECM
P0054 HO2S Heater Resistance Sensor 2 ECM
P0068 Throttle Body Airflow Performance ECM, PCM
P0069 Manifold Absolute Pressure - Barometric Pressure Correlation PCM
P0097 Intake Air Temp Low Voltage PCM
P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage PCM
P0101 Mass Air Flow (MAF) Sensor Performance ECM, PCM
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency ECM, PCM
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency ECM, PCM
P0106 Manifold Absolute Pressure (MAP) Sensor Performance ECM, PCM
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage ECM, PCM
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage ECM, PCM
P0112 Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage ECM, PCM
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage ECM, PCM
P0116 Engine Coolant Temperature (ECT) Sensor Performance. ECM
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage ECM, PCM
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage ECM, PCM
P0120 Throttle Position (TP) Sensor 1 Circuit ECM, PCM
P0121 Throttle Position (TP) Sensor 1 Performance ECM, PCM
P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage ECM, PCM
P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage ECM, PCM
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control - ECM, PCM
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature ECM, PCM
P0130 HO2S Circuit Sensor 1 ECM, PCM
P0131 HO2S Circuit Low Voltage Sensor 1 ECM, PCM
P0132 HO2S Circuit High Voltage Sensor 1 ECM, PCM
P0133 HO2S Slow Response Sensor 1 ECM, PCM
P0134 HO2S Circuit Insufficient Activity Sensor 1 ECM, PCM
P0135 HO2S Heater Performance Sensor 1 ECM, PCM
P0136 HO2S Circuit Sensor 2 ECM, PCM
P0137 HO2S Circuit Low Voltage Sensor 2 ECM, PCM
P0138 HO2S Circuit High Voltage Sensor 2 ECM, PCM
P0140 HO2S Circuit Insufficient Activity Sensor 2 ECM, PCM
P0141 HO2S Heater Performance Sensor 2 ECM, PCM
P0171 Fuel Trim System Lean ECM, PCM
P0172 Fuel Trim System Rich ECM, PCM
P0201 Injector 1 Control Circuit ECM, PCM
P0202 Injector 2 Control Circuit ECM, PCM
P0203 Injector 3 Control Circuit ECM, PCM
P0204 Injector 4 Control Circuit ECM, PCM
P0218 Transmission Fluid Overtemperature TCM
P0220 Throttle Position (TP) Sensor 2 Circuit ECM, PCM
P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage ECM, PCM
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage ECM, PCM
P0230 Fuel Pump Relay Control Circuit ECM, PCM
P023A Charge Air Cooler (CAC) Coolant Pump Relay Control Circuit PCM
P0300 Engine Misfire Detected ECM, PCM
P0315 Crankshaft Position (CKP) System Variation Not Learned ECM, PCM
P0324 Knock Sensor (KS) Module Performance ECM
P0325 Knock Sensor (KS) Module Performance ECM, PCM
P0326 Knock Sensor (KS) Performance ECM, PCM
P0327 Knock Sensor (KS) Circuit ECM, PCM
P0328 Knock Sensor (KS) Circuit ECM
P0335 Crankshaft Position (CKP) Sensor Circuit ECM, PCM
P0336 Crankshaft Position (CKP) Sensor Performance ECM, PCM
P0340 Intake Camshaft Position (CMP) Sensor Circuit ECM, PCM
P0341 Camshaft Position (CMP) Sensor Performance ECM, PCM
P0351 Ignition Coil 1 Control Circuit ECM
P0352 Ignition Coil 2 Control Circuit ECM
P0353 Ignition Coil 3 Control Circuit ECM
P0354 Ignition Coil 4 Control Circuit ECM
P0365 Exhaust Camshaft Position (CMP) Sensor Circuit ECM
P0366 Exhaust Camshaft Position (CMP) Sensor Performance ECM
P0411 Secondary Air Injection (AIR) System Incorrect Air Flow Detected ECM
P0412 Secondary Air Injection (AIR) Solenoid Control Circuit ECM
P0418 Secondary Air Injection (AIR) Pump Control Circuit ECM
P0420 Catalyst System Low Efficiency ECM, PCM
P0442 Evaporative Emission (EVAP) System Small Leak Detected ECM, PCM
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit ECM, PCM
P0446 Evaporative Emission (EVAP) Vent System Performance ECM, PCM
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit ECM, PCM
P0451 Fuel Tank Pressure (FTP) Sensor Performance ECM, PCM
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage ECM, PCM
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage ECM, PCM
P0454 Fuel Tank Pressure (FTP) Sensor Intermittent ECM, PCM
P0455 Evaporative Emission (EVAP) System Large Leak Detected ECM, PCM
P0461 Fuel Level Sensor Performance ECM, PCM
P0462 Fuel Level Sensor Circuit Low Voltage ECM, PCM
P0463 Fuel Level Sensor Circuit High Voltage ECM, PCM
P0464 Fuel Level Sensor Circuit Intermittent ECM, PCM
P0480 Cooling Fan Relay 1 Control Circuit ECM, PCM
P0481 Cooling Fan Relay 2 Control Circuit ECM, PCM
P0482 Cooling Fan Relay 3 Control Circuit ECM, PCM
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge ECM, PCM
P0502 Vehicle Speed Sensor (VSS) Circuit Low Voltage ECM, PCM
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent ECM, PCM
P0506 Idle Speed Low ECM, PCM
P0507 Idle Speed High ECM, PCM
P0520 Engine Oil Pressure (EOP) Sensor Circuit ECM, PCM
P0532 (A/C) Air Conditioning Pressure Sensor Circuit Low Voltage ECM, PCM
P0533 (A/C) Air Conditioning Pressure Sensor Circuit High Voltage ECM, PCM
P0562 System Voltage Low ECM, PCM, TCM
P0563 System Voltage High ECM, PCM, TCM
P0575 Cruise Control Switch Signal Circuit ECM, PCM
P0601 Control Module Read Only Memory (ROM) ECM, PCM
P0601 Transmission Control Module (TCM) Read Only Memory (ROM) TCM
P0602 Control Module Not Programmed ECM, PCM
P0602 Transmission Control Module (TCM) Not Programmed TCM
P0603 Control Module Long Term Memory Reset ECM, PCM
P0603 Transmission Control Module (TCM) Long Term Memory Reset TCM
P0604 Control Module Random Access Memory (RAM) ECM, PCM
P0604 Transmission Control Module (TCM) Random Access Memory (RAM) TCM
P0606 Control Module Internal Performance ECM, PCM
P0607 Control Module Performance ECM, PCM
P060D Control Module Accelerator Pedal Position (APP) System Performance- ECM
P062F Control Module Long Term Memory Performance ECM
P062F Transmission Control Module (TCM) Long Term Memory Performance- TCM
P0621 Generator L-Terminal Circuit ECM, PCM
P0622 Generator F-Terminal Circuit ECM, PCM
P0641 5-Volt Reference 1 Circuit ECM, PCM
P0645 Air Conditioning (A/C) Clutch Relay Control Circuit ECM, PCM
P0650 Malfunction Indicator Lamp (MIL) Control Circuit ECM, PCM
P0651 5-Volt Reference 2 Circuit ECM, PCM
P0685 Engine Controls Ignition Relay Control Circuit ECM
P0689 Engine Controls Ignition Relay Feedback Circuit Low Voltage ECM
P0690 Engine Controls Ignition Relay Feedback Circuit High Voltage ECM
P0700 Transmission Control Module (TCM) Requested MIL Illumination ECM
P0705 Transmission Range (TR) Switch Circuit TCM
P0711 Transmission Fluid Temperature (TFT) Sensor Performance TCM
P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage TCM
P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage TCM
P0716 Input Speed Sensor Performance TCM
P0717 Input Speed Sensor Circuit Low Voltage TCM
P0719 Brake Switch Circuit Low Voltage ECM, PCM, TCM
P0722 Output Speed Sensor Circuit Low Voltage TCM
P0723 Output Speed Sensor Circuit Intermittent TCM
P0724 Brake Switch Circuit High Voltage ECM, PCM, TCM
P0741 Torque Converter Clutch (TCC) System - Stuck Off TCM
P0742 Torque Converter Clutch (TCC) System - Stuck On TCM
P0751 1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear- TCM
P0752 1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear- TCM
P0756 2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear- TCM
P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear-TCM
P0833 Clutch Pedal Switch 2 Circuit ECM, PCM
P0842 Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage TCM
P0843 Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage TCM
P0961 Line Pressure Control (PC) Solenoid System Performance TCM
P0973 1-2 Shift Solenoid (SS) Control Circuit Low Voltage TCM
P0974 1-2 Shift Solenoid (SS) Control Circuit High Voltage TCM
P0976 2-3 Shift Solenoid (SS) Control Circuit Low Voltage TCM
P0977 2-3 Shift Solenoid (SS) Control Circuit High Voltage TCM
P1101 Intake Air Flow System Performance ECM, PCM
P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage- ECM
P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage- ECM
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage- ECM
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage- ECM
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage-ECM
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage- ECM
P1133 HO2S Insufficient Switching Sensor 1 ECM, PCM
P1134 HO2S Circuit Insufficient Activity Sensor 1 ECM
P1174 Fuel Trim Cylinder Balance ECM
P1182 Supercharger Inlet Pressure Sensor Performance PCM
P1183 Supercharger Inlet Pressure Sensor Circuit Low Voltage PCM
P1184 Supercharger Inlet Pressure Sensor Circuit High Voltage PCM
P1258 Engine Coolant Over Temperature - Fuel Disabled ECM, PCM
P1400 Cold Start Emission Reduction Control System ECM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance- ECM, PCM
P1574 Stop Lamp Switch Circuit ECM, PCM
P1621 Control Module Long Term Memory Performance ECM
P1629 Theft Deterrent Fuel Enable Signal Not Received ECM, PCM
P1630 Theft Deterrent Learn Mode Active ECM, PCM
P1631 Theft Deterrent Start Enable Signal Not Correct ECM, PCM
P1632 Theft Deterrent Fuel Disable Signal Received ECM, PCM
P1668 Generator L-Terminal Control Circuit ECM, PCM
P1680 Control Module Accelerator Pedal Position (APP) System Performance- PCM
P1681 Control Module Throttle Position (TP) System Performance PCM
P1682 Ignition 1 Switch Circuit 2 ECM, PCM
P1810 Transmission Fluid Pressure (TFP) Position Switch Circuit TCM
P1811 Maximum Adapt and Long Shift TCM
P1816 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio TCM
P1818 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio -TCM
P2101 Control Module Throttle Actuator Position Performance ECM, PCM
P2119 Throttle Closed Position Performance ECM, PCM
P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit ECM, PCM
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage ECM, PCM
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage ECM, PCM
P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit ECM, PCM
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage ECM, PCM
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage ECM, PCM
P2135 Throttle Position (TP) Sensor 1-2 Correlation ECM, PCM
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation ECM, PCM
P2176 Minimum Throttle Position Not Learned ECM, PCM
P2227 Barometric Pressure (BARO) Sensor Performance PCM
P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage PCM
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage PCM
P2430 Secondary Air Injection (AIR) System Pressure Sensor Circuit ECM
P2431 Secondary Air Injection (AIR) System Pressure Sensor Performance- ECM
P2432 Secondary Air Injection (AIR) System Pressure Sensor Circuit Low Voltage- ECM
P2433 Secondary Air Injection (AIR) System Pressure Sensor Circuit High Voltage- ECM
P2440 Secondary Air Injection (AIR) System Shut-Off Valve Stuck Open ECM
P2444 Secondary Air Injection (AIR) System Pump Stuck On ECM
P2534 Ignition 1 Switch Circuit Low Voltage ECM
P2535 Ignition 1 Switch Circuit High Voltage ECM, PCM
P2610 Control Module Ignition Off Timer Performance ECM
P2763 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage TCM
P2764 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage TCM
P2A00 HO2S Circuit Closed Loop (CL) Performance Sensor 1 ECM
P2A01 HO2S Circuit Sensor 2 ECM
U0001 High Speed CAN Communication Bus PCM
U1300 Class 2 Data Link Low PCM
U1301 Class 2 Data Link High PCM
U1305 Class 2 Data Link Low or High PCM
U1500 Inter-Device Dedicated Bus Malfunction VCIM
U2100 Controller Area Network (CAN) Bus Communication- BCM, EBCM, ECM, IPC, PCM, PSCM, Radio, SDM, TCM, VCIM
U2103 Fewer Controllers On Bus Than Programmed- IPC, Radio, SDM, VCIM
U2105 Lost Communications with Engine Control System- BCM, EBCM, PSCM, TCM
U2106 Lost Communications with Transmission Control System- BCM, EBCM, ECM
U2107 Lost Communications with Body Control System- EBCM, ECM, IPC, PCM, PSCM
U2108 Lost Communications with ABS/TCS Control System BCM
U2109 Lost Communications with Powertrain Multiple Control System EBCM
U2111 Lost Communications with Steering Control System BCM
U2113 Lost Communications with Sensing Diagnostic Module (SDM) BCM
U2116 Lost Communications with Instrument Panel Cluster (IPC) BCM
U2125 Lost Communications with Mobile Communications Control Systems- BCM
U2137 Lost Communications with Vehicle Theft Deterrent (VTD) BCM
U2172 Lost Communications with Digital Radio Receiver (DRR) BCM
023 Seat Belt Tension Sensor Circuit Out of Range PPS
024 PPS Ignition 1 Voltage Performance PPS
063 PPS Out of Calibration PPS
064 Communication/ID Performance PPS
065 Sensor Circuit Out of Range PPS
*PLEASE NOTE- Not all DTCs are used in all Cobalt models
B- Body System DTCs
DRR - Digital Radio Receiver (XM Satellite)
ECM - Engine Control Module
PPS - Passenger Pressence System (Airbags)
SDM - Sensing Diagnostic Module (Airbags)
TCM - Transmission Control Module (Automatic Only)
VTD - Vehicle Theft Deterrant module
Old 02-07-2006, 04:57 AM
The Stig
MarcS's Avatar
Dtc P0171
DTC P0171
Conditions for setting this fault:
1. The long term FT weighted average value is more than a calibrated value.
2. The above condition is present for more than 2 minutes.
Conditions for DTC/CEL reset (note MIL=CEL):
1. The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
2. A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
3. A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
4. Clear the MIL and the DTC with a scan tool.
Notice the light should go off after 3 ignition cycles if the problem is fixed, the fault will come off the history after 40 ignition cycles.
Stuff you can check at home without a scan tool that could cause this condition:
1. Missing, loose, or leaking exhaust components
2. Vacuum leaks at the intake manifold, throttle body, and injector O-rings
3. The air induction system and air intake ducts for leaks
4. The crankcase ventilation system for leaks
5. The evaporative canister purge pipes for obstructions or plugging
In GMs Service Information, Document ID #'s 1704292 and 1704374, both pertain to p0171.
Old 05-04-2006, 01:53 PM
Moderator Alumni
zinner's Avatar
This CEL is set also when the LTFT is above 20% in any of the trim cells. Usually it means your MAF isn't registering all the air passing by it, either you have a leak or the intake messed up the air flow enough so the MAF isn't registering all the air passing by, like oil on the maf, ect.
Old 05-23-2007, 08:41 PM
I'm old school
Halfcent's Avatar
Is your check engine light (CEL) on? Read this!
Here is a new sticky to try and help with the rising number of threads about this topic. Many people post asking what to do if their check engine light turns on. The light is actually called a "Malfunction Indication Lamp", or MIL for short, because even though it shows a picture of an engine, it could be an error code from some other system. These should be your first steps.
For some psychological reason, when that light turns on, people get scared. They think if they keep driving the car it will break. They think they shouldn't take it to a dealer because they are worried their modifications will make them lose their warranty. None of these things should bother you.
First, when and since the light came on, has the car seemed to be running fine? If so, then relax. You should be able to safely drive the car to wherever you need to go. Now, if something obviously went wrong with the car when the light came on, like for instance, the "Engine Power Reduced" message was displayed, and the car runs poorly, well then something broke. It will be obvious to you NOT to drive the car, if you even can.
Second, get it scanned. It has always blown my mind to see people post for over a week about how their MIL is on, and despite numerous people telling them to go get it scanned, they don't. Just do it! There are several options for doing this. Most auto parts stores will scan your car for free. You can buy your own scanner if you want for as little as $50. Or, you can do what you really should do... Take it to the shop!
Is the car under warranty? If so, take it to the dealer. Lets take two scenarios. First one is you have basically a stock car with no modication. In this case, you have no argument. None. Take it in. Most of the time, dealers will not necessarily tell you which code you activated, they will simply fix it. If you want to know what happened, you will probably have to ask.
Now lets say you are modified to some degree. If you are reading this, then I am assuming that this might be your first time dealing with car modification and warranty work. Here's the deal. Take it in under warranty. 9 times out of 10, they will still fix it and never say a word about whatever you have done to your car. If the modifications you have are responsible for your MIL, the dealer may take the following steps;
a. Fix it anyway
b. Tell you they can't fix it because it's not a stock part. Put your stock part back on.
c. Void a specific part of your warranty.
Okay, there it is, item "c". Everyone just read that and said to themselves "Jesus! I don't want to do that!" Well, it would irresponsible of me to make this thread and not include that as a possibility. But KEEP READING! For a dealer to take such a step is a serious issue. They will know that you either specifically abused the car, or the parts you have are in fact directly responsible for a failure. Additionally, the warranty of your car is broken down into several small pieces. When a portion of your warranty is either voided, or simply expires by time or mileage, several other parts of your warranty are still in force. For instance, your bumper to bumper warranty is 3/36. But your corrosion warranty is like 10 years or something crazy high like that.
Here is my situation. I have a completely custom built powertrain. My dealer knows all about it, and they actually think it's pretty cool. And yet, my powertrain warranty is still in tact as far as GM records go. Now if I throw a rod tomorrow and expect my dealer (or any other) to fix it, I'm stupid for trying. They will obviously open the engine up and see a set of Eagle rods in there and not warranty that. My point is, my dealer hasn't taken the specific action to void the warranty even though they know about my car. There is another member on this board named Biohazard that dropped a freaking wrench across his power distribution box under his hood, blew up his trans controller, and guess what, they replaced it for free.
What is the most common modification that causes a MIL? The aftermarket intake, causing a P0171 code. Let's say that's you. You have an intake, you get a MIL, you take it to the dealer and they tell you it's a P0171 and you have an aftermarket intake an they can't do anything for you. Is that a problem? Hell no. In fact, they fixed the problem in this case by simply scanning and clearing the code. Do you need to actually fix anything? Nope, that particular code is just really fussy. Is the dealer going to void your powertrain warranty? No way.
Now say you have aftermarket cams in your engine and you get a MIL. You should STILL take it to the dealer and get it scanned. Before they do any actual work to your car, they will tell you what is wrong. If it has anything to do with your cams, then say "thank you", and pick up your car and leave. If you had the smarts to install a set of cams, then you probably have the smarts to know how to fix a problem with them. But what if that code has nothing to do with your engine? Now you can get it fixed for free.
Okay, third possibility, the car isn't under warranty any more. Guess what? Go to the dealer and get it scanned (are you sensing a trend here?). You already know it's no longer under warranty, so whats the harm?
Some more stuff. MIL codes are programmed to turn on, and off. If the problem that turned the light on in the first place goes away, the light may turn itself off. You should STILL go get it scanned. Whenever a code is triggered, whether your MIL light is on or off, the code remains stored in memory. Getting it scanned and cleared will tell you what happened in the first place. And it will remove that code from the memory, so should a new code be activated, there won't be any confusion.
One more word of note. Your computer may have codes in memory and NOT turn on your MIL. Some errors codes are only designed to turn the MIL on if they are sensed more then once. So if you get a scan without your MIL on, and you have errors codes, that's actually pretty normal.
Now, lets say you actually where a good boy or girl and got it scanned and you know the DTC error code number. Good Job! Now take that number and go to this thread:
https://www.cobaltss.net/forums/showthread.php?t=12015
While most DTC codes are universal, there are always some that are vehicle specific. So that thread will tell you the exact problem. Now if you want help with that problem, go look around on the rest of the board. Please don't post your problem here, because this thread is not meant to be a trouble-shooting resource. Have fun!
Old 06-01-2007, 08:29 PM
SS SCHGD's Avatar
My car (the red one with stage 2) threw 4 codes while I was on vacation, but none of them set off the display. I wouldn't have known about any of them had the cruise control not stopped working. (we took it in right when we got home) First was the cruise control code (clutch to shift ratio), then a temperature code for the power steering motor, and then 2 radio codes one ground issue and one current over issue. Such a finicky electric system. Am running a aftermarket amp and speaker setup with the factory stereo and using my sunroof (or radio fuse, I forget) to turn on my equipment which is the current issue. The ground issue is that the speakers are all disconected from the factory system.
The power steering thing was explained to me as doing parking manuevers while the car is extremely warm, my example 90+ temps, sunny, sitting in the sun all day windows closed, black interior, no window tint, and jumping in and trying to parrelel park or something....
Anyway, I wouldn't have known any of this without going to the dealer to get the codes checked.
The cruise control code will reset itself and cruise will be active again after 41 warm up cycles....that means starting car, and driving and it warming up to a certian setting, then shutting off....And you can't set the code again durring that time. That ment 1200 miles without Cruise control :-(
Old 06-02-2007, 09:26 AM
TCarter's Avatar
ive noticed the cruise control doesnt want to resume if you hit 120+ then slow down to resume..
even if you turn the cruise control button on and off and try to reset it. it takes about 10min or so for it to finaly resume.
Good Write up Halfcent!
Old 06-04-2007, 06:49 PM
SS SCHGD's Avatar
My Cruise seemed to work just fine at 120.....
Old 06-15-2007, 11:40 AM
Not a Sebring
WhiteSSBalt's Avatar
I've had CEL's for my AEM CAI and then again when I put the full exahaust on (b/c of the XTC de-cat downpipe). The CEL is still on until I get it tuned with HP Tuners.
Old 06-15-2007, 12:24 PM
06blackg85ss's Avatar
amen man..... aeroforce gauge is a great thing to have too... along with my laptop and hptuners software
Old 06-15-2007, 12:27 PM
M-Dub's Avatar
I haven't had a CEL except for the short I had when it said my Airbag deployed! Other than that I haven't had any CEL's from my CAI, or Stage 2, smaller pulleys or anything!
Old 06-15-2007, 09:36 PM
Not a Sebring
but you also have a 2.0SS/SC of which HP Tuners is all over for, probally have a cat, and probally have an intake actually designed for your car. Us 2.4 guys are forced to use the 2.2 intakes if we want a CAI. While they fit the same, the 2.2 intakes weren't initially designed to be used on the 2.4's. All that model specific "MR tuning" and whatnot on those Injen intakes probally dosen't do a whole lot of good for 2.4s. Also, not having a cat overheats your rear O2 sensor which causes the ECU to dump extra fuel to cool the cat, therefore messing up your air/fuel ratio, throwing a CEL. And its one thing having an '06 2.4SS, b/c at least there is SOME tuning for those. But everywhere i've been that has HP Tuners says that the '07 2.4SS's are different than the '06's and are still in Beta testing for them, and they don't wanna blow my car up, so i'm told to "wait patiently". I've even been told by some shops that they can't even log the '07 2.4SS's ECU into HP Tuners yet.
Sucks to have a 2.4SS. Sucks it's an '07. And it sucks to be un-tuned.
lol
Old 06-16-2007, 03:26 PM
rycobaltls22's Avatar
lol
What do you mean? At least you guys have some kind of tuning confirmed for the Hahn kit, and VVT!
Old 06-16-2007, 03:56 PM
MikeyMo84's Avatar
i got P0171 and it turned out the brake booster hose had a hole chafed in it from rubbing on a sharp point of the transmission
Old 06-16-2007, 09:14 PM
Not a Sebring
lol, and NO ONE who wants to tune it!!! I've been promised a few things here and there by various people, but nothing ever seems to go through. Plus, the '07 Beta isn't quite 100% yet, which I know is a matter of being patient b/c its an '07, but still....
And I don't want the Hahn kit. Hell, like I said, I can't even get basic tuning (raised redline, upped top speed limiter, dialed in bolt-ons, tuning for the injector swap, better/earlier VVT kick, shut off rear O2 sensor, etc etc), nontheless some drastic upgrade like a turbo, lol. Plus, I don't have the time, the money, or the available downtime it takes to turbo the 'balt, nor do I want to spend the extra money on the tuning its gonna take to dial that sucker in, and I enjoy my 30mpg, as my cars a daily driver and is driven alot. (21k since I bought it back in October). N/A for me my man.
Old 06-16-2007, 10:46 PM
I'm old school
Halfcent's Avatar
While all this is great, what does tuning availability have to do with properly handling a MIL?
Old 07-17-2007, 03:10 PM
djkaloci2004's Avatar
okwerwq
sorry my cousin was messing around and ran into me
Last edited by djkaloci2004; 07-17-2007 at 03:10 PM. Reason: Automerged Doublepost
Old 10-15-2007, 01:52 PM
stage2cobaltss's Avatar
I Got A Question... I Ran Mine And Got 2 Codes.. One Is Running Rich And The Other Is Random Cylinder Misfire... Any Clue? I Have A 06 Ss Sc Stage 2 Aem Inatke,gmpp Exhaust
Old 12-14-2007, 07:38 PM
nuttzzy's Avatar
i have this prob after i installed some headers and cat the only thing i found is a o2 senser was not secure and the wire got crimped so i uncrimped the wire and looked no breakage of insulation or anything but the light is staying on is there a way to just reset it manualy like the change oil light? or does the dealer have to clear it
Old 12-14-2007, 10:07 PM
I'm old school
Halfcent's Avatar
Anybody with a scanner can clear it. Autozone can do it. I do not recommend just unplugging your car battery, because that also clears your fuel trim data.
Old 12-14-2007, 10:08 PM
nuttzzy's Avatar
i was told to pull the fuse to the ecm will that mess it up?
Old 12-15-2007, 03:36 PM
I'm old school
Halfcent's Avatar
That is the same thing as disconnecting the battery. It will clear the entire memory. Yes, it will get rid of the Check engine light, but it will also clear the fuel trim memory.
However, you are missing the entire point of this thread. What is your trouble code? You don't know, because you didn't get it scanned. It might not be the O2 sensor. It probably is, but you don't know.
Go get it scanned!
Old 12-17-2007, 06:55 PM
jdub777's Avatar
that was exactly what i needed to hear. I installed an injen cold air intake and the damn engine light went on. Now i know i can just go over to the dealership to get it scanned. Thanks man, nice thread.
Old 12-17-2007, 06:58 PM
anthonyS88's Avatar
my cel is on due to a broken ass rear o2 sensor that broke when i took it off to change dp's
Old 01-14-2008, 04:20 PM
Tyler Rinehart's Avatar
Unhappy
On Saturday I was coming back on the interstate and all of a sudden my check engine light came on, i had noticed that my car was running a little sluggish a when i first started....i took it to the dealer b/c it is still under waranty and they said I need a new fuel injectore....odd if you ask me, the car is only and 06.
Quick Reply: The Cobalt DTC thread (merged)
