The Cobalt DTC thread (merged)
Old 12-29-2008, 02:22 PM
  #126
ViSiONZ's Avatar
Great thread!
Very useful!
Old 01-13-2009, 12:01 PM
  #127
Cragar03's Avatar
My check engine light has been on for awhile every month or so out of nowhere it says reduce engine power and 3rd gear floored will make it to 40 and no higher. it feels like im running on 2 cylinders. If i turn it off for a min or take the neg of the battery for a min its fine for another month. Any answers to that one?
Old 01-13-2009, 01:44 PM
  #128
I'm old school
Halfcent's Avatar
First off all, stop disconnecting your battery. That is not how you clear a trouble code.
Second, please read the very first post of this thread. It clearly tells you that if you have a CEL, we can do nothing to help you unless you get it scanned and give us the trouble code.
Lastly, engine power reduced is a sign of something really bad. Don't ignore it, and don't floor it in 3rd trying to make it go faster.
Old 03-07-2009, 05:33 AM
  #129
2009cobaltss27's Avatar
one question if i get hard pipe for
my 2009 ss/tc will i void my warrenty??????
need feed back tanx
Old 03-07-2009, 08:54 AM
  #130
umrdyldo's Avatar
need feed back tanx
What you do in your spare time is your own business.
Hard pipe? come on wtf is that. This is not a warranty discussion thread.
Old 03-08-2009, 02:48 PM
  #131
I'm old school
Halfcent's Avatar
That is correct, you really haven't posted in the right place.
Old 03-14-2009, 09:47 PM
  #132
francismoores's Avatar
need help
i was comming home today and I lost most the power from my engine and my engine light is on the screen it said engine power reduced. and theres no leaks. do anyone know what is wrong with it
Old 03-23-2009, 01:07 PM
  #133
rockstar014's Avatar
mines on bc i broke a part of the thread for the o sensor for the dp
Old 04-25-2009, 08:14 PM
  #134
aikin198's Avatar
what is the fuel trim memory and how bad is it if you were to erase it. i've unplugged my battery a few time while putting systems and running led's and never seen any problems with anything. Sorry i'm kinda new at all this. i just put a gmpp intake on my 2.2 and it ran fine all last night and today until about an hour ago and the cel went on, the car is still running fine tho
Old 04-26-2009, 12:48 AM
  #135
I'm old school
Halfcent's Avatar
Resetting the memory via battery disconnect is not bad. The car just has to start over with the fuel trim learning is all. That's one reason why I always tell people to use a scanner to clear MIL's instead of just disconnecting.
As far as your MIL, you should disconnect the battery and let it reset. With the new intake, you want it to relearn the fuel trim. BUT, first make sure that's what the actual problem is by scanning it first!
Old 05-04-2009, 01:37 PM
  #136
aikin198's Avatar
thanks halfcent my friend has a scanner and scanned it and thats all it was. i cleared it out and im all set, thanks for letting me know what the fuel trim was im kinda new to all this.
Old 05-07-2009, 04:42 PM
  #137
mrgrinch's Avatar
Since you guys are all talking about CEL. Has anyone put a CAI on their car and had the check engine light come on?
I got a CAI for my 2.4L N/A and everytime i put it on shortly after the CEL comes on "System too Rich" is the code. I can feel the difference, powerwise in my car, but again something is wrong and the CEL is on. I put back on the stock CAI and CEL goes away.
Help Anyone?
Old 05-07-2009, 09:13 PM
  #138
I'm old school
Halfcent's Avatar
Sir, you desparately need to try using the search feature. The MIL code for using aftermarket intakes is HEAVILY discussed in other places. Like here:
https://www.cobaltss.net/forums/sear...archid=6692673
or the sticky thread on the topic here:
https://www.cobaltss.net/forums/showthread.php?t=12508
Old 05-12-2009, 04:36 PM
  #139
mrgrinch's Avatar
thanks. 1st forum didn't work and 2nd told me a lil usefull info. but nothing that helps.
Old 06-02-2009, 08:51 PM
  #140
2005REDSS's Avatar
yeah idk what to do i welded a straight pipe on witch i know isnt anything but my engine power redused light came on an went off now my engine light is on an wont go off well im going to chevy tomorrow to get it looked at an ill let everyone know what went wrong or broke
Old 06-02-2009, 10:12 PM
  #141
robby ss's Avatar
when i put my intake on my check engine light come on then after driveing about 40 miles on highway is says Engine Power Reduced wat this means and my car is runing rich
Old 06-03-2009, 06:00 PM
  #142
2005REDSS's Avatar
Does any body have a clue what a PCM code is. Or what does this do if it pops ona nd the power reduced light comes on.
Old 06-04-2009, 11:51 AM
  #143
I'm old school
Halfcent's Avatar
Again, this thread is not about troubleshooting specific problems. Please try a search about intakes.
Now this is a more general question suited to this thread. A PCM is a Powertrain Control Module. Powertrain means engine and transmission. Some Cobalts, like the LSJ's use a PCM.
An ECM is an Engine Control Module. It controls the engine only. A TCM is a Transmission Control Module. As you might figure, it controls the transmision only. All of the Cobalts that use an automatic transmission use both an ECM and TCM together.
The LSJ cars could have used an ECM instead of PCM since a manual transmission doesn't need a control module. But GM used an existing model PCM when they developed the first Cobalt LSJ just because, and didn't use the trans controlling portion of it.
A "Code" is an error sensed by one of these modules and then recorded in a numerical code that you can then read using a tool called a scanner. Some error codes are serious issues, like misfiring, that the module is programmed to reduce the available power in your engine in order to protect it from damaging itself.
Is your Check engine light on? That is called a Malfunction Indicator Lamp, or MIL, and it's telling you that one of your modules has a code recorded. Now go read post number one again.
Old 06-08-2009, 12:27 AM
  #144
Dragonsfire12345's Avatar
thanks to this thread I got a headache and worries fixed with ease today..... stupid little fuse
Old 07-08-2009, 07:36 PM
  #145
rrauter's Avatar
So maybe some of you can be more useful then the dealership was. So recently I got into an accident and since then my power steering died one morning, only to come back later that day and my idle stays at about 1400+ rpm (2.2L btw), and my trunk release doesn't work (key fob or the button inside the car)... anyways, I took it in and all I get is "it could be due to your aftermarket deck or headlights maybe." Im pretty frustrated, but what i did get outta them is that my fuel trim reading is 29% and code number p0171 (lean) and that i have a p0102 (map low frequency). Also my CEL is on and has been for 2 months maybe and is still on after going to the dealership. I haven't had any of these problems except the trunk which I've had for about 5 months. Can someone enlighten me with some knowledge? Thanks
Old 07-08-2009, 10:39 PM
  #146
I'm old school
Halfcent's Avatar
You have much bigger problems then this thread is designed to handle. I suggest starting a new thread and describe where the collision damage was. And its not your headlights, sheesh.
Old 07-10-2009, 06:21 PM
  #147
rrauter's Avatar
thanks halfcent. yeah i'll try that and see what anyone says.
Old 07-13-2009, 04:53 PM
  #148
SS SCHGD's Avatar
Alright, so I got my oil Changed today and I got my cruise control code cleared. They said the Code is P0833. All then info I can get on it would be apreciated. It does not light up the MIL when it comes on, just doesn't allow me to use the Cruise control. I have a 2006 Cobalt SS/SC with a Stage 2 GM tune.
I bought a OBD II reader but it does not see the code for me to clear it. Can anyone help me find a program for the OBD II reader that will read and delete it, or maybe it can be un programed (or the fault setting can be adjusted) with HP tuners or something?
Thanks.
Old 09-05-2009, 01:32 PM
  #149
blaze2712's Avatar
Ok so my cel has came on and i tried to scan it with my obd II but when ever i go to like it it will come up with an "err" on the screen. And it wont show any codes. any help would be great.
Old 09-10-2009, 10:32 AM
  #150
I'm old school
Halfcent's Avatar
I would say either your scanner is bad, or something in your ECM's memory is bad. Check the scanner on a couple of other cars to see if it reads normally. If it's fine, get your car looked at.
Quick Reply: The Cobalt DTC thread (merged)
