Codes, Codes, Codes!
Hey folks, long time no post. Glad to be back. =)
Driving home from work today, my CEL came on about two minutes after I started the car. I was doing about 50 km/hr and was approaching a four way stop. Cloudy and muggy, since it has been raining/snowing for the last few days. Got home and pulled my CarChip and checked the codes: P0104 - Mass or Volume Air Flow Circuit Intermittent P0003 - Fuel Volume Regulator Control Circuit Low P0400 - Exhaust Gas Recirculation Flow Malfunction P0765 - Shift Solenoid D Malfunction C0665 - Chassis Pitch Signal Circuit C0600 - ??? I have a trip log showing what time the codes were thrown at and what speed, engine speed, etc at the time if that helps. Is there anything I can do to remedy it myself? Is it safe to just reset the CEL? What should I look at before thinking about taking it to the dealer? Just over 63 000 km so no more bumper to bumper warranty but I still have my power train and emissions. Thanks! :cssNET: |
clear all dtc's and see if they come on again, sounds like a little bit of a glitch on the sensors.
"ive got hoes... in different area CODES, area CODES, area CODES" - ludacris
Originally Posted by ryaan
(Post 4977813)
Originally Posted by outtamymind
(Post 4977694)
Originally Posted by Chad92
(Post 4978079)
hahaha :)
Thanks Steve! Hope everything is well with you! |
Check to make sure your Emiss fuse or pwer train relay are not loose.
Under the hood fuse box. Also check the box for water intrusion,if its wet inside put the hair dryer to it. |
Originally Posted by Coblasts
(Post 4979284)
(Post 4978347)
np, and they will be eventually. i'm hoping to come up that way a few times this summer for some fun at castrol
