could use a little help here
so today I had to rush my puppy to the hospital because she was sick so being in a rush I pulled into a driveway quick bottomed out hard and threw my car into limp mode.. no code yet but deff went into limp mode.. after leaving to go home I got a cel so once I got home I scanned it and it came up as the maf sensor so I cleaned it let it dry put it back in.. yes I put it in the right way.. but then my car will start up and stall instantly so I did a little investigating and it seems I might have dented the charge pipe now my question is would the charge pipe be causing the car to stall out or could it maybe be the maf sensor anything else I should check for please let me know I use the cobalt as my dd so I need to try and get it up and running soon
I mean I checked the bottom of the intercooler it looks fine doesn't even look like it was touched.. just ordered some injen pipes.. and a new maf sensor so ill try that first ill try looking at the intercooler a little bit better tomorrow though.. thanks
Yep my end tanked cracked pretty bad just ordered a mpx intercooler front bumpers off alredy so got that.. Injen charge pipes and im in the process of respraying the bumper to plug up the license plate holes.. So at least it gave me a little motivation to do some work to the car
