Cruise Control and E Brake Issue
Cruise control stopped working. I jiggled the clutch and brake and I also changed the PCM fuse which is what the cruise runs off of. Any other ideas?
And the ebrake isnt working. The button pops out? I have no idea. |
Don't know about the ebrake, but I have had to disconnect my battery several times in 5 years to get my cruise working again.
Check to see if you have a brak light out. Someone correct me if I'm wrong but I believe the cruise uses the resitance of the brake lights as a test before it allows cruise to work.
Cruise control wide if u press the button for cruise and try to engage it in thr cluster itll say cruise engaged or somthing but wont work i can fix this when i tune u. Also the ebrake i have a new ebrake handlw and key at my plave so we can replace that as well. I bought it new for 125 from gm. But i found them for 35ish $ . If u give me 25$ and the tuning monwy ill fix it all for u.
Slash- that would make sense because I do have a brake light that just went out. Lol. I have had the replacement bulb for a while I just need to get it installed. Didn't have a wrench on me at the time I bought them.
Chevy- the ebrakewould be cool. As soon as I get the injectors and pulley and what not ill let you know. |
okie dokie bro, just keep me posted, wehn we doing the tuning and ect.
Changed the bulb and got my turn signal working again. Cruise still doesnt work. Guess the next thing ill do is unplug my battery and plug it back in?
