Cruise control is glitching
Old Dec 1, 2007 | 11:31 PM
CobaltVenomSS's Avatar
Angry Cruise control is glitching
Yet another CobaltVenom Problem!!!!!
on my way home from work (i was exhausted) is a 20 mile highway of a 70MPH zone and i just wanted to relax and use cruise control well my car said i couldnt
i get the car to 70 turn cruise on and push the set button and it says cruise engaged for less then a second then goes away and im like WTF!!! it didnt even set
why!!!!!!!!!!!
Old Dec 1, 2007 | 11:32 PM
Red2.4SS's Avatar
Is your brake light switch staying on? If so it won't engage.
Old Dec 1, 2007 | 11:34 PM
im sorry but ive never heard of a brake light switch...if u mean the brake light in the guages???it was off
Old Dec 1, 2007 | 11:39 PM
Red2.4SS's Avatar
The switch behind the brake pedal that turns on the brake lights. As soon as the brakes are hit the cruise control turns off. So if the switch is on when its not supposed to the brake lights will be on when your not on the pedal and the cruise control wont work.
Old Dec 1, 2007 | 11:41 PM
i didnt notice the brakes on when i was passing the reflectors on a construction zone road
Old Dec 1, 2007 | 11:46 PM
cobaltss2006frank's Avatar
dude just disconnect the battery for about 10 mins and it will work.
Old Dec 1, 2007 | 11:47 PM
SSMOKEM's Avatar
Mine does the same thing. It has to do with the clutch being suppressed while driving or some thing along those lines. It throws a code, but the cel doesn't come on.You have to clear the code at the dealer or unhook the battery for a bit.
There's a topic some where on here about.
Old Dec 1, 2007 | 11:48 PM
Red2.4SS's Avatar
Hmmm....
Were you pressing resume instead of set when you were setting the speed?
I think I remember doing that and it said it was engaged, but it was set for 0 MPH cause I had just turned on cruise control.
Old Dec 1, 2007 | 11:49 PM
alright ill try that out tomorrow
nope i was hitting the bottom button and it wouldnt work i even hit the resume button and it would glitch on that one too
Last edited by CobaltVenomSS; Dec 1, 2007 at 11:49 PM. Reason: Automerged Doublepost
Old Dec 1, 2007 | 11:54 PM
Red2.4SS's Avatar
Yeah I'd try the disconnect battery reset, maybe it just went wacky?!
Old Dec 1, 2007 | 11:55 PM
SSMOKEM's Avatar
https://www.cobaltss.net/forums/show...cruise+control
Here ya go. The code is thrown if you put even the slightest pressure on the clutch "rest your foot, but not actually suppressing it." Look at the 7th post.
Old Dec 2, 2007 | 12:00 AM
chood711's Avatar
mine does the same thing....let me know if unhooking the battery works.
Old Dec 3, 2007 | 11:13 AM
fr33k's Avatar
On some balts, GM put a felt pad on the brake pedal and the felt gets compressed over time. The switches are so precise that even the thickness of that felt being compressed will keep your cruise from working.
GM put that on the clutch pedal cruise release switch too. If you have an SS/SC or others with manual trannys, check both.
Old Dec 3, 2007 | 04:04 PM
06_SS_S/C's Avatar
The problem is a code that gets through by the clutch switch. You won't get a CEL but it will cause the cruise to stop working. Just unplug the battery for a while to reset it or if you have an interceptor you can clear the code or take it to autozone and they can clear it.
Old Dec 3, 2007 | 04:11 PM
M-Dub's Avatar
It is because you have thrown a Clutch Pedal code! If you do not let completely off the clutch at least 1 time out of 7 pushes it will throw that code which disables your cruise control! I had to relearn how to drive a stick at first because it happend to me 3 times... I haven't had it now in almost 2 years now!
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
