Doesnít Want To Decelerate - Cobalt SS Network
Go Back  Cobalt SS Network > General > Problems/Service/Maintenance
Doesnít Want To Decelerate >
Old 07-11-2018, 04:39 AM
So,
At one point I had a pretty common issue Iíve read about. Basically a surge from 5-1.5k at idle and when pressing in the clutch. My fix was indeed a vacuum leek. I was planning to dig into the throttle body and clean it but this fixed it so I put it aside. Now Iím noticing when I downshift, regardless what rpm Iím at, the car lurches and the exhaust note changes as if Iím holding the throttle open slightly. It jumpes around and stumbles debating on whether to decelerate or excelerate. What gear or rpm doesnít change that fact. Iím starting to get lurching while my foot is off the gas in first gear. Also, if Iím traveling speed and I pull into neutral it sits above 1-1.5rmp until I rest at a complete stop. My tuner hooked a scan tool to his laptop while on a drive around and showed on the data that the computer is holding my throttle at 20 to 25% occasionally when my foot is not on the gas pedal. Any thoughts?
Does she just want to go faster all the time!?
BOMEXCOBALT is offline
Old 07-11-2018, 08:53 AM
What Cobalt do you have? Mods and tune? Any engine codes?
jdbaugh1 is offline
Old 07-11-2018, 11:28 AM
06 SS/SC. Cold air intake, 3Ē catless exhaust, long tube headers. Other then that, stock. It is throwing an engine code. Itís always on. From what I remember is something about air flow/fuel? I could read it again if that would help.
Old 07-11-2018, 11:58 AM
It could help considerably
jdbaugh1 is offline
Old 07-11-2018, 12:34 PM
Iíll be at my tuners place at 12:30. Iíll have it posted then.
Thank you for your help brother!
Old 07-11-2018, 12:37 PM
Haven't helped you yet lol but I do know that with the electronic throttle being ECU controlled, having a sensor read funny can make it do strange things.
jdbaugh1 is offline
Old 07-11-2018, 03:00 PM
I got stopped without tags. Ordered custom plates on my birthday and was trying to hold off so I didnít have to pay for registration 2 times for the same car in a week 😐 my luck.
Iíll the the results of the reading posted as soon as I get out of this hell hole. Wish me luck lol.
Old 07-12-2018, 09:37 AM
My tuner wasnít available to run the codes for me, so I pulled the throttle body off and cleaned it up. No fix after ~70 miles. All the gunk from the rag was in the throttle body 😯 Was easy to take apart. 1 vac line and 1 sensor.
Chav97
01-02-2017 08:31 PM
vpec13
The Lounge
24
12-12-2011 09:31 PM
baddabang15
The Lounge
06-10-2011 12:01 PM
Erod
The Lounge
24
11-11-2007 11:27 PM
Dman
The Lounge
12-13-2005 02:35 AM
Quick Reply: Doesnít Want To Decelerate
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
