DTC 2228 code
Ok well i bought the 0w30 that mobil 1 has and changed my oil this morning,so after i change it i turn the car on and let run for a little bit(so far so good)and then shut it off and washed my car.So after i wash my car i went to start it and as soon as i did the cel came on but the car was running ok.I scanned the code and got a 2228 code=barometric pressure circuit low.So do you think it is just getting used to the oil or it's to thin?I have already double checked everything,any help will be appreciated,thanks.
make sure you didn't bump the baro sensor, wires, connector.....that's the sensor by the oil filter cap.
^^ ya dude that happened to me that fucked my shit up the sensor got disconnected then it thru all diff kinds of codes and fucked my pressure couldnt go over 40 mph luckily i was still under warranty
Might of damaged the wire going into the connector with the extension ,or not plugged it back in all the way if you removed it..
Another thing to check is that the pins didnt get bent if you had removed it and put it back. |
I forgot to plug it back in:red:damn i feel like a moron,thanks guys.
no problem......happens to everyone at one time or another :)
