E-Brake wont work at all
Old Feb 15, 2010 | 02:06 PM
CobaltVenomSS's Avatar
i usually let my car warm up before i leave in the morning but today when i started it and was about to get out it started rolling back...so i pushed the brake in and pulled up on the ebrake as far as it would go and it still rolled back...
1. the brake light is still on
2. and ive noticed when driving a few weeks back the ebrake light will flash for a split second..
whats wrong??
Ttt.
Last edited by CobaltVenomSS; Feb 15, 2010 at 02:06 PM. Reason: Automerged Doublepost
Old Feb 15, 2010 | 02:07 PM
JPizzle's Avatar
Cable broke? Does it make that ratchet sound at all?
Old Feb 15, 2010 | 02:08 PM
yea it makes the noise when i pull it up if thats what ur talking about
Old Feb 15, 2010 | 02:10 PM
JPizzle's Avatar
Yea I was. Hmmmm..... I have heard about this before on here. I forgot what it said though.
Old Feb 15, 2010 | 05:17 PM
rnjmur's Avatar
There are two cables, one for each rear caliper, that apply the brakes when the e-brake is pulled. The two cables attach to a H shaped piece under the e-brake handle which attaches to the handle itself. If the cable(s) stretch, or if the springs on the rear caliper(s) that attach to the e-brake cables stop working the e-brake cables can "slip out" of the H shaped piece. If that happens you will no longer have an e-brake. If the car is still under warranty then take it into the dealership and have them fix it.
If not under warranty then pop the plastic off from around the e-brake handle and check the cables. You maybe able to adjust the ebrake, but you also need to check if the rear calipers are bad otherwise you could cause more issues if you adjust them.
Old Feb 15, 2010 | 07:15 PM
ufnwish's Avatar
this happened to my 06 brook right at the handle stealership replaced it for free
Old Feb 15, 2010 | 07:22 PM
BlackJackSS's Avatar
well then y refer to them as a stealership if they replaced it for free???
sorry i work at a dealership, some ppl just dont understand.
My parking brake is loose in the handle. I think it might be from just yankin on it a lil hard lol. mayb u should lay off the roids sir
Old Feb 15, 2010 | 08:43 PM
ufnwish's Avatar
cuz the stealership less than a mile from me well lets just say idk if there giving away free cars and happy ending with every visit will never see me again i now drive 30 miles to get my car worked on
Old Feb 16, 2010 | 12:50 AM
i drive 0 miles to get my car worked on.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
