Every spark plug question Answered
Old 10-08-2010, 03:27 AM
  #51
kissrocker52's Avatar
so what do you suggest to use with a 2.4 should i go colder plugs or stick with stockers
Old 10-08-2010, 03:41 AM
  #52
twiztedblkss's Avatar
so do the 3787 work for the tc? i think they would be a good option since they are pregapped to .032
Old 10-09-2010, 02:19 AM
  #53
Old 10-19-2010, 03:50 PM
  #54
NGKTECH's Avatar
Yes these will work for the turbo engines
Old 10-26-2010, 01:52 AM
  #55
LSJ
LSJ's Avatar
Mods: GM Stage 2 & ZZP 3" Intake
I will installing my cat-back next spring, as well as the ZZP long-tube header/DP, when it's available.
BKR7E?
Or..
BKR6E?
Old 10-26-2010, 07:08 AM
  #56
Administrator
Administrator
Staged07SS's Avatar
BKR7E?
Or..
BKR6E?
Stock plugs are fine with GMS2, and your mods. Just adjust the gap if you start to experience spark blowout.
I ran my stock plugs up until I pullied down to a 73mm pulley on my H62 blower & GMS3 tune. Only then did I notice the stock heat range was to hot for my application.
Old 10-26-2010, 08:30 AM
  #57
LSJ
LSJ's Avatar
And that would be BKR7E?
Old 10-26-2010, 08:38 AM
  #58
Administrator
Administrator
Staged07SS's Avatar
No.
BKR7E are one step cooler copper plugs.
Stock plugs are heat range 6, and are either platnium or iridium (depending on year).
What I was trying to say is it will be silly for you to change your plugs (unless they have a lot of miles on them). The stock plugs will be fine for your setup.
Old 10-26-2010, 08:40 AM
  #59
LSJ
LSJ's Avatar
No.
Ohhhhhhhh.. I assumed that was the stock NGK plug.. I'll have to take one out and look at it then, unless someone knows the number offhand.
It's a 2006, if that helps.
Yeah, I am due for some new plugs though.
Old 10-26-2010, 08:57 AM
  #60
LSJ
LSJ's Avatar
Well.. It says "BKR6E which is simply a v-power plug at a 6 heat range which is stock."
And the stock is IFR6V-10G, gapped at .040
Either are fine it looks like, I just need to determine gap now.
Old 10-26-2010, 09:06 AM
  #61
Administrator
Administrator
Staged07SS's Avatar
Those came in my late model 07' stock, but they were gapped at 0.035". I wouldnt use that large of a plug gap on a stage 2 car though.
I know that 05's & 06's (along with early model 07's) came stock with platnium NGK plugs.
Old 10-26-2010, 09:19 AM
  #62
LSJ
LSJ's Avatar
I searched on NGK and that's what they gave me, and factory may have been gapped at .040, but they should be what, .038?
Theoretically, you want the largest gap without problems like it breaking up in high RPMs.
Old 10-26-2010, 09:34 AM
  #63
Administrator
Administrator
Staged07SS's Avatar
Yes, I know that's what NGK's site gives you, but in most owners manual they call for the platnium plug that's all I'm trying to get at. I know all about the reasoning why you want the largest gap possible, but once you start flowing more air you will want to start to tighten the gap up.
My car came from the factory with the iridium plugs you listed, but they were gapped at 0.035". That has always been the sweet spot plug gap for most lsj's. It is still large enough to promote a strong spark, but small enough to avoid spark blowout once you start to pulley down.
I didnt start experiencing spark blowout at that gap until I pullied down to a 74mm pulley, and finally a 73mm pulley. I now run one step cooler plugs gapped at 0.032".
Old 10-26-2010, 10:25 AM
  #64
NGKTECH's Avatar
Stock plugs for 06 should be the NGK IFR6V-10G
Unfortunately that plug is still a dealer only item so you would use the platinum version which is PFR6T-10G stock# 5542
NGK.com - Cross Reference Search Results
Old 10-26-2010, 10:33 AM
  #65
OniMirage's Avatar
I never bothered but I guess I should look into getting the 8's. Been on the 7's with a .40 gap for years and they work fine.
Old 10-26-2010, 10:39 AM
  #66
Administrator
Administrator
Staged07SS's Avatar
8's on a GMS2 setup?? I wouldnt bother man. The 7's are plenty cool enough for your current setup.
Old 10-31-2010, 01:28 PM
  #67
averagewhiteboy's Avatar
How about for the non-boost cars..??
Old 01-14-2011, 12:56 AM
  #68
Closed Diff's Avatar
Sweeeet Thread!
Old 02-29-2012, 02:09 PM
  #69
victoryredturbalt's Avatar
??????ngk??????
Old 02-29-2012, 02:17 PM
  #70
I thought i've heard don't gap the bkr7e's before is this true??
when i got my ottp stg2 kit it came with these plugs and i was under the impression that they come correctly gapped so i didn't mess with them. car runs fine, only it misses a little bit every here and there in idle.
Old 02-29-2012, 03:37 PM
  #71
06cobalt racer's Avatar
what is a good gap to have with a 2.8 pulley with 17 psi? i have one step colder plugs
Old 03-01-2012, 07:24 AM
  #72
Administrator
Administrator
Staged07SS's Avatar
0.032"-0.035"
All depends on the car & supporting mods.
The more air you bring in, the more chances of having spark blowout when running a larger gap.
Never assume a plug is gapped right from the manufacture or vendor.
Always check the gap yourself, and adjust accordingly.
Old 03-04-2012, 05:30 PM
  #73
ZZP COBALT's Avatar
Originally Posted by Nitrousexpress
Heres all the information from Graham @ NX and Brandon with NGK..
NGK aside from being the plugs I use personally are the OEM distributor for plugs on these cars.
Supercharged cars First
SC - The factory plug on 04-05 redlines and 05 cobaltss cars is the PFR6T-10G. They changed that to a IFR6V-10G which is the same plug but a iridium platinum plug.
So i bought NGK Iridium BKR6EIX spark plugs for my 2005 Cobalt SS Supercharged off zzp cause i had ran them in my honda before this and had no problems with idle or anything. My car only has a 3" catted downpipe and a k&n intake, i have NO injector or pulley mods, will these be fine in my car? I am not tuned for the downpipe/intake right now but mid april I'm going to zzp to get the 1.0 pcm, what should i tell them to let them know that these are in my car if need be? But last and finally, will these be fine on my setup?
Old 03-05-2012, 07:17 AM
  #74
Administrator
Administrator
Staged07SS's Avatar
Yes.
Old 08-14-2012, 12:36 AM
  #75
jmiller15's Avatar
okay this might be a nub question, but do our plugs need to be torqued, and if so what are the numbers?
as well could someone please recommend a plug for me, mods in sig...
Only change is instead of budget tune i've upgraded to the regular 24 psi trifecta tune.
Quick Reply: Every spark plug question Answered
