Flashing CEL
Had this problem for over 3months already, took it to the dealer twice! quick run down,
98% of the time, takes me 3trys to start the car, which i have to add gas to start it up, & if it starts up, it sounds like a QUAD ! not power at the crank what so ever, when i went to the dealer they replaced all listed below.. The first time i went they replaced-- Fuel Module Assembly IGN Module Spark Plugs Still was misfiring & no power at crank sometimes.. The second time i took it they replaced -- P0606 ECM Condition Replace PCM. as well as perform crankshaft off set releran procedure interal failure of ignition module-replaced battery & starter drags, may have bad starter Which they didnt bother to replace.. ===== Results, Still misfires, doesnt start up, No power.. takes 3-5tries to start now, need to add gas also.. Any ideas on what may be causing this? im sick of going back and it not being fixed |
Well the flashing check engine light just means massive misfire(catalyst damaging levels of misfire)
Is it only seeting a P0300 or is setting indvidual codes? (301, 302, 302, 304) Does it set any other codes? My first guess would be that its not actually a failure but a bad connection at the ICM. It could very easily be a coil assembly. |
il ask the dealer tomorrow, im taking it back in the morning
but they honestly suck at finding out whats causing this |
| All times are GMT -4. The time now is 04:11 AM. |
