GM employees
Or anyone who is able to, anyway you could pm or post any and every recall or tsb for the ss/tc? My car is definitely having issues now, and I'm pretty sure it's not tune related. It's just not holding boost, and last night it went up to 22, and just fell down to 10. And driving it today and last night, it just wasn't making the power it normally does. After this weekend I'm probably going to take it in to get looked at, and it would be helpful if I at least knew some common problems, searching has brought me nothing. Help a girl out! Thanks. :)
boost leak?
boost leak?
thats good that you want to learn about your car but if its warranty does it really matter as long as its fixed?
Not a GM employee but your problem sounds like it MIGHT be one of the following:
Beyond that if you're losing that much boost with no CEL the only other thing I could think of is the charge piping seal around the turbo itself. |
Yes I would like to know what's wrong with my car lol. Doesn't seem like your typical boost leak, everything is super tight. It also is an intermittent problem, it doesn't happen ALL of the time, but it seems to be getting more frequent.
#09-06-93-004: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator) - (Jul 21, 2009)
#PIP4669: Intermittent DTC P2261 Setting - keywords air boost cac charge chevrolet control cooler driveability ecm engine gas hole intermittent inf low maf map mil pipe power reduced reducedpwrmde ses turbo - (Jul 7, 2009) #PIP4559: DTC P2227 After Turbo Upgrade Kit Installation - keywords accessory air boost cal calibration cel charge control cooler driveability DTC ECM engine gas leak inf low MAF MAP MIL PCM performance power - (Jan 13, 2009) #PIP4520: Low Boost / Power And/Or DTC P0299 Or P0101 - keywords actuator boost CAC charge control cooler driveability DTC ECM engine gas lnf low maf MIL reduced reducedpwmde SES wastegate - (Nov 4, 2008) #PIP4485: Low Boost, Reduced Power and/or DTC - keywords air cac charge control cooler driveability ecm engine gas hole lnf low maf mil P0101 P0299 P2178 pipe power reduced reducdpwrmde rub ses start stall - (Sep 26, 2008) #07-00-89-058C: Astra - New Model Features and Service Guide - (Sep 11, 2008) #PIC3385E: Repeated Park LPS Fuse Open (Additional Information) - keywords B2585 B2585-06 B2625 B2625-02 BCM brake DTC dimming hazard IPC MIL repeat STG SYS - (Aug 14, 2008) |
Originally Posted by Rissa
(Post 4142741)
I would prepare to lose your tune if I were you though....updating the ECM calibration is common practice at some dealers for drivability issues, and its recommended for several codes. |
Ill look it up on alldata right now
Ok i just looked on alldata and their is a page of probably 30 tsb's
Here ya go buddy enjoy 01-07-30-036H 01/29/2009 A/T Control - DTC P0756 Diagnostic Tips 00-00-90-002J 01/28/2009 Tires - Correct Inflation Pressure Information 07-08-98-001A 01/28/2009 Body - Non-Approval of Clipping For Collision Repair 05-03-10-020B 01/22/2009 Tire - Use Of Nitrogen Gas In Tires 09-08-67-001 01/06/2009 Body - Rattling Noise From The Sunroof Area 01-06-01-011E 12/18/2008 Gasoline Engine - Oil Consumption Guidelines 08-06-04-033C 12/18/2008 Engine Controls - Aftermarket Calibration Identification 08-08-42-005A 12/17/2008 Lighting - Headlamp Replacement Guidelines 06-08-50-009C 12/12/2008 Restraints - Passenger Presence Sensing System Info. 08-08-44-032 12/10/2008 Audio System - iPod(R)/iPhone(R) Won't Connect To Radio 06-09-41-004H 12/03/2008 Interior - Passenger Air Bag Is Not Flush With Dash 00-03-10-006D 11/26/2008 Tires - Radial Force Variation (RFV) Info. 07-03-10-008A 11/26/2008 Tires - Slight/Mild Edge Feathering Information 03-03-10-007D 11/24/2008 Wheels/Tires - OE Tire/Wheel Characteristics 07-03-10-013D 11/24/2008 Wheels/Tires - Vibration While Driving 08259A 11/06/2008 Campaign - Inoperative OnStar(R) System 07-07-30-010A 10/30/2008 A/T Controls - Snapshot Data Upload Information 08-06-03-009A 10/29/2008 Electrical - Reducing Intermittent Electrical Concerns 06-08-50-005C 10/01/2008 Interior - Seat Cushion Cover Is Loose 00-00-89-027E 09/29/2008 Interior - Elimination Of Unwanted Odors 08-08-44-010D 09/29/2008 Navigation Radio - Diagnostic Information 01-07-30-032E 09/29/2008 A/T - 4T65E Fluid Leaking From A/T Vent 08-08-46-006 09/25/2008 Audio System - XM(R) Terrestrial Repeater Changes 06-08-44-012C 09/18/2008 Navigation System - DVD Navigation Updates Program 06-06-93-001E 09/15/2008 Engine - Ticking Noise On Cold Start Up (Normal) 06-08-111-004A 09/15/2008 Body - Exterior Emblem Discoloration/Blistering/Peeling 05-03-10-005D 09/11/2008 Wheels/Tires - Upsized Wheel/Tire Characteristics 02-08-42-001C 09/05/2008 Lighting - Headlamp Polycarbonate Lens Damage Prevention 07-03-10-016C 08/29/2008 Wheels/Tires - Required Label When Changing Wheels/Tires 08-08-44-028 08/28/2008 Audio - Inadvertent Steering Wheel Button Activation 03-08-48-006E 08/25/2008 A/C - Rear Window Defroster Grid Contact/Tab Repair 08-07-30-039 08/21/2008 A/T Controls - Service Fast Learn Adapts Characteristics 08-08-126-001 08/15/2008 Navigation Radio - XM NAV(R) Traffic Coverage Areas 08-09-41-002A 08/14/2008 Restraints - Air Bag Lamp ON/Various DTC's Set 08-08-46-004 08/14/2008 OnStar(R) - Aftermarket Device Interference Information 08-08-44-026 08/11/2008 Audio System - Refurbishing Radio Faceplates/Knobs 08-07-30-035 08/08/2008 A/T - Water Or Coolant Contamination Information 05-06-04-022E 08/06/2008 Fuel System - TOP TIER Detergent Gasoline (Canada) 06-03-09-005B 07/30/2008 Suspension - Rear End Squeak/Squawk on Low Speed Bumps 02-06-03-008D 07/21/2008 Charging System - Low Voltage Display/Battery Discharged 04-06-04-047H 06/24/2008 Fuel System - 'TOP TIER' Detergent Gasoline Information 08-08-64-011 06/23/2008 Mirrors - Heated Mirror Defrosting Time 08-08-44-023 06/18/2008 Navigation Radio - Adaptation After Radio/Battery R&R 07-03-16-004A 06/18/2008 Tire Monitor System - FAQ/Diagnostic Information 05-00-89-072B 06/17/2008 Engine/Fuel System - Oil/Fuel Additive Information 99-04-20-002E 06/06/2008 Drivetrain - Driveline Clunk Information 08-07-30-026 05/22/2008 A/T - Slight Vehicle Movement In Park At Start Up 07-08-49-020B 05/22/2008 Instruments - IPC Odometer Programming Reference Guide 08-03-10-007 05/16/2008 Tires - Minimizing Damage to TPM Sensors 01-07-30-010C 05/12/2008 A/T - Torque Converter Replacement Information 08-03-16-003 05/12/2008 Tire Monitor System - TPM Sensor Information 00-05-22-002K 05/06/2008 Disc Brakes - Warranty Service and Procedures 01-08-42-001F 05/02/2008 Lighting - Exterior Lamp Condensation Guidelines 03-07-29-004E 05/02/2008 M/T - Operating Characteristics of Manual Transmissions 08-03-10-005 05/01/2008 Wheels/Tires - Chrome or Chrome Plated Steel Valve Caps 08-03-10-006 05/01/2008 Wheels/Tires - Tire Slowly Loses Air/Low Tire Message 02-06-03-009C 04/17/2008 Electrical - Battery Charging Tips/Recommendations 05-06-03-002C 04/17/2008 Battery/Charging System - Electrical Diagnostics Info. 00-06-01-012C 04/14/2008 Engine - Use of 'Surface Conditioning Disks' 08-06-01-008 03/27/2008 Engine - Accessory Drive Belt Noise Diagnostics/Tool 08-03-10-004 03/25/2008 Wheels/Tires - Accessory Wheel/Tire Mounting/Balancing 08-08-51-002 03/12/2008 Body - TPO Fascia Cleaning Prior to Painting 04-08-50-006B 01/25/2008 Interior - Seat Cover Wrinkle/Crease/Crack/Burn Info. 06-00-89-029D 01/10/2008 Interior - Cleaning of The Interior Surfaces |
Originally Posted by Maven
(Post 4142782)
No recalls I know of that could cause that, three issues Ive seen and at least one of them has a information notice about is: charge piping rubbing on the radiator support bolts(Steddys car did this, and was even worse with Hahn piping), nipple breaking off charge piping near TMAP, and only other boost realted thing ive seen is a broken wastgate valve. The nipple breaks off the valve and has to be replaced.
Wow i wasnt expecting it to post so many this damn site pisses me off sometimes, anyways thats all the tsb's listed. It does tell you the fix for everything but it wont let me copy it.
Heellp!! :( Also it doesn't throw any codes, and I've had it scanned twice.
It did on all stock, psykosteve, and terminator tunes?
Didn't have the Terminator tune on long enough to know, stock it did a few times, I'm going to put that ECU in tomorrow and see how it is. I really don't think it's the tune though.
Would a clogged cat increase or decrease boost?
increase
idk from what I was reading it'll decrease it
Reading where. POST!! lol
Lol from where? Post!!! ...this site is being gay again |
hey didn't you just have an oil change?
Yours sounds simliar http://forums.fourtitude.com/zerothr...ostid=55726843 |
I did just have an oil change, and my vin fits into the range of cars affected by the Recall. I should have that checked out.
wat do u normally spike boost at? and wat does it usually hold?
stock dp? |
Stock dp, it doesn't spike, it goes up to 22 and holds.
o then its a boost leak for sure. didnt u change ur intake lately? u check all ur t-bolt clamps? all of them dont b lazy
No the new intake is not on yet, I haven't checked quite everything yet to make sure it's tight. There's a recall that my car fits into, and a couple TSB's that could have the cause.
