help please
the car went into engine power reduced while driving. It will start then shuts right off. Any ideas why and how to fix it
Do you have a code reader?
need more info, when did this happen like accel decel what temp the car was at how you were driving it. stuff like that, and codes.
Check the muffler bearings
Wow^
there were 3 codes p0017, p0102, and p0315 and i just started driving so temps wernt high and it was when i was slowing down for a stop sigh could it be i have a exhaust leak near the engine bay and it got in the intake and made the tb dirty?
if you have an exhaust leak near the engine bay, like before the first o2 sensor, then you can throw a code. happened to me.
edit: but it doesnt look like those codes are related to that. p0017: P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B) p0102: OBD-II Trouble Code: P0102 Mass Air Flow (MAF) Circuit Low Input idk p0315. i just googled them |
so what could be the problem for it going into this mode?
could it be from fouled spark plugs?
probably has something to do with the 3 codes you are throwing. unplug and plug your maf back in, that worked for me way back when
P0315 is crank position...
u need to warm ur car up before driving maybe its the camshaft position sensor or the crankshaft position sensor i think is dirty it happened to me before then now it all sudden came off
