High Beams won't turn on when stick pushed forward, but will when pulled back.
Old Apr 25, 2010 | 11:44 PM
lilskarvcx's Avatar
Unhappy High Beams won't turn on when stick pushed forward, but will when pulled back.
I don't know if it's a recent problem or not, but when I push the left stick forward, it will not turn the brights on. They will however turn on if you pull it towards you. Now, when I turn the knob at the end of the stick, and then push the stick forward, the brights stay on. Did I blow a fuse? Which one?
Old Apr 25, 2010 | 11:56 PM
scotch89's Avatar
wouldnt hurt to check the fuse. it should be in the engine bay, once u remove the cover flip it up side down and it well say hd light i think. im not sure if there a fuse for the brights.....did u do anything like hids?
Old Apr 26, 2010 | 01:07 AM
Nighthawk243's Avatar
If this is occurring with the autolights, I'm gonna say that the control stick is bad.
Old Apr 26, 2010 | 01:58 AM
lilskarvcx's Avatar
I installed 3rd gen projectors. only spliced the halos to the daytime running lights. That's why I suspected a burnt fuse. I appreciate the help.
If it helps any, the icon on the dash board does appears when i pull the stick back. It does not light up when I push it forward.
Old Apr 26, 2010 | 10:52 AM
chris88z24's Avatar
Relay
Old Apr 26, 2010 | 10:44 PM
lilskarvcx's Avatar
Is it just too much power to the headlights or did i screw something up wiring them?
Just unplugged the highbeam fuses and plugged them back in for lack of a better idea. That must have reset something, because they're working now.
Last edited by lilskarvcx; Apr 26, 2010 at 10:44 PM. Reason: Automerged Doublepost
Old Apr 28, 2010 | 09:11 PM
lilskarvcx's Avatar
aaaanddd.... the problem is back again...
Old Apr 28, 2010 | 09:17 PM
TommyP's Avatar
AWD > FWD
take it in and get the switch replaced, that should be your problem. Sounds like the foreword flick that turns on the high beams isn't working.
Old Apr 28, 2010 | 09:47 PM
lilskarvcx's Avatar
the flicker brights worked after i took out the fuses and put them back in
Old Apr 28, 2010 | 09:49 PM
TommyP's Avatar
AWD > FWD
that's a different direction on the switch though, could just be that one direction.
Old Apr 28, 2010 | 10:48 PM
lilskarvcx's Avatar
nooonono, when i pull back it works all the time, it periodically works when i push it forward. I have to keep taking the fuses out and putting them back in to get that direction of the control stick working again
Old Apr 28, 2010 | 10:54 PM
insylem's Avatar
IVe seen stuff like that before.
Happens to other electronic devices as well. Home PCs, aircraft avionics ect...
Take the fuse out, spray either rubing alchole or an electrical contact cleaner in the slot where the fues goes, and put in a NEW fues (same type/rateing) that SHOULD get you back going again.
allpro666
Oct 6, 2015 08:11 PM
Trav3480
Oct 1, 2015 08:17 PM
Cptnslo
Sep 24, 2015 09:32 AM
The Rookie24
Sep 20, 2015 04:33 PM
jonnycat
Sep 19, 2015 12:58 PM
