Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   High idle issue after cleaning throttlebody (https://www.cobaltss.net/forums/problems-service-maintenance-69/high-idle-issue-after-cleaning-throttlebody-306285/)
enRg Jan 24, 2014 12:08 PM
Hey all. Yesterday I cleaned my throttle body out, and unknowingly without unplugging the battery, i opened it while cleaning it. I figured I un calibrated when I did this, and I'm wondering if it will re-learn the proper RPM to idle at..
At first, i was idling at 2300, now today, its idling at 1500RPM, but whats weird is if i force the RPM's down in 1st gear, it will idle at about 8-900. when i step on the gas, it will go back up to idling at 1500-2000 RPM. I have no mods on the car except for a k&n air filter. stock intake! I've tried everything....
it threw the idle code, and the reason I initially cleaned it is because it was throwing the MAF code, though everything seemed to be fine i decided to get some throttle body cleaner and clean it a bit. I'll probably need to take it to my local chev dealership and get the ECM reset, and replace the MAF sensor.. any suggestions?
Xmetalhead2003X Jan 24, 2014 12:11 PM
It will relearn after a while. Mine is usually after 50 or 60 miles. Disconnect the battery and wait a couple minutes for the reset.
enRg Jan 24, 2014 12:17 PM
I disconnected the battery for about 30 mins yesterday and it didn't really make a difference. I think its hard coded in the computer.
enRg Jan 24, 2014 12:25 PM
I've searched tho forum already, And I'm really hoping i can find a different solution... Thanks guys!!!
qwank Jan 24, 2014 03:11 PM
mine took a few days of driving o go back to normal. don't worry about it too much, just drive it.
what engine do you have?
enRg Jan 24, 2014 03:21 PM
I have an ecotec LE5 2.4L
on a side note; when i drive it, and i put it in neutral and decelerate, it fluxuates between 1500 and 3500 rpm unitl i come to a complete stop, hen it will either sit idle at 2000 or 1500... weird.
enRg Jan 24, 2014 03:24 PM
on a side note; when i drive it, and i put it in neutral and decelerate, it fluctuates between 1500 and 3500 rpm until I come to a complete stop, when it will either sit idle at 2000 or 1500... weird.
qwank Jan 24, 2014 03:40 PM
that's all normal for what happens a few miles after you clean the throttle body.
I doubt your MAF sensor is the actual cause of your code. usually something else causes that code to come on. only time the MAF is usually the problem is if you have a stalling condition and/or driveability problem that goes away when the MAF is unplugged.
don't bring it anywhere until your idle straightens out though.
enRg Jan 24, 2014 03:50 PM
I drove it to work.. which is a 3 minute drive from my house.. oops.
i have an appointment with my local GM dealership tuesday
qwank Jan 24, 2014 04:14 PM
no, I mean dont take it to the dealer until the idle straightens out, otherwise they will be chasing the unstable idle when you know that's only because you cleaned the TB.
drive the shit out of it this weekend to get the idle stable.
enRg Jan 24, 2014 04:20 PM
Okay. I figured an ECU flash would fix it though..? Oh well. I guess im just worried to f#$k it up.
Xmetalhead2003X Jan 24, 2014 04:54 PM
It really just needs drove around a while and it will fix itself. Been through it every year with routine maintenance.
enRg Jan 24, 2014 05:20 PM
Is there any odd behavior that i should be looking for that would throw this whole situation off? I'm no mechanic and i want to be sure.
You guys have been extremely helpful by the way...:cssNET:
Xmetalhead2003X Jan 24, 2014 05:34 PM
Not really. Mine hangs around 1-1200 and drop to 800 then normal while in neutral. It usually gets better and not as much over time.
enRg Jan 24, 2014 05:41 PM
When i throw it in neutral and start slowing down with just the brake, it fluctuates from really low to really high. thats the biggest thing that bothers me! :confused:
qwank Jan 24, 2014 07:39 PM
yeah it's annoying, but all part of the ECM's learning process.
having the dealer reflash it will immediately relearn the idle, but why pay for something that will eventually work itself out for free?
zipo1200 Jan 24, 2014 09:59 PM
Exactly! haha. i am watching This car as well and hooking up my livewire to check the "Actuall TB compared to what the computer says it should be at" it has been 24 hours and its already improving idle. just need the off load idle to calibrate faster :)
enRg Jan 24, 2014 10:04 PM
Well it idles from 1000-1500 now. If i drive it it will fix itself? its a little harsh on shifting since it revvs up when i put the clutch in all the way, but i guess it just has to be dealt with.
ItalianJoe1 Jan 24, 2014 10:28 PM
Check that you don't have any vacuum leaks, that's what it sounds like you are dealing with.
If you clean the TB and reset the ECU by disconnection power for a while it should be fairly close. If not, then there is something else allowing air in that the car can't compensate for.
You didn't move the butterfly in the TB right, just cleaned it? I've seen people loosen the screws and not re-position the blade properly and have similar issues.
enRg Jan 25, 2014 12:49 AM
No vacuum leaks, as im inexperienced with these cars as of right now, and cars in general, i.. well, he moved the butterfly. so it must be a calibration issue! its slowly getting better
enRg Jan 25, 2014 01:45 AM
I just noticed when I'm faster than 20 in neutral, it will constantly bounce anywhere from 1500-3500 while slowing down. It's starting to piss me off! Ahhhhh!
qwank Jan 25, 2014 09:33 AM
is your check engine light still on?
enRg Jan 25, 2014 11:19 AM
It's intermittent. right now its off. we pulled the code and it was the high idle code, i don't exactly remember the code though. i know for sure it was the high idle one..
qwank Jan 25, 2014 10:00 PM
your low idle and maf codes could have been the dirty throttle body, you may have fixed it, just need to keep driving it. I never got a high idle code after I did mine though.
enRg Jan 27, 2014 11:58 AM
UPDATE: Hey everyone. I just wanted to let you know this happened on friday and it's now monday, and the problem is pretty much resolved by driving. It got better as each day went by, so I'm probably cancelling my appointment with Chev. Thanks for all the help!
