ho2 sensor questions
well i tried getting my inspection and my ho2 sensor wasnt ready.....asked them why and all they said was its cold...to drive around and bring it back. so i drove idk like 30 miles came back same ****...
wondering wats the fix for this i have no codes and car drives fine so any help is very apreciated
thanks in advance
thanks in advance
hmmm thats weird may be you have a sensor going bad the rear o2 sensor has an open circut for like the first 15 min of starting the car or untill it reaches a certian temp...then it switchs to a closed circut and double checks all its findings....i would imagine youd throw a cel for something like that tho
anyway deleting it messed up the reading from the machine??
no it sounds like the problem is that the o2 sensor is not reaching operating temp. but not throwing a code...if you have an interceptor youd be able to pin point it a little to see what volts the sensors are running at...but it honestly sound like the sensor is going bad....if you didnt have insection id say just let it till it threw a code..but idk maybe someone else may have a better solution..
so im assuming since that is ready i can pass inspection even with the h02 sensor not being ready..... but if not i guess ill get a "real" one for extra
After clearing codes the general rule we tell customers is to ride for a week or two before going to the emissions station. What happens is when you clear the codes it resets the PCM flags. Once the flags have been reset every code in the ECM must run and pass before the emissions station will pass your car.
yes sir..
thats was my thinking as well... since my inspection is expired they told me i have 15 days to fix it so i been driving like crazy lol since then my scanner says the evap system is ready and later today im gonna scan it and see if the h02 is ready
if this is not the problem does it mean i have a bad o2?
Last edited by 55supercharged; 07-03-2010 at 05:01 PM. Reason: Automerged Doublepost
