Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   Intermittent wiper problems (https://www.cobaltss.net/forums/problems-service-maintenance-69/intermittent-wiper-problems-26763/)
06G5GT Jul 23, 2006 01:11 PM
Having a wiper problem and wondering if anyone else has experienced it.
Driving along with the wipers on intermittent. Rain gets heavier so I turn the switch to low speed. Wipers continue at intermittent speed. Have to put them on high speed to be on all the time. And no, it's not that I have the stalk in the wrong spot because I was sitting in a parking lot doing this after coming outside and they went from intermittent to high only.
alleycat58 Jul 23, 2006 02:04 PM
Sounds like something the dealer needs to fix, sounds like the problem is in the switch.
06G5GT Jul 23, 2006 02:18 PM
For sure. The problem is recreating the problem while at the dealer. It doesn't always happen.
biniecki Jul 23, 2006 02:22 PM
I have a question. Are our wipers speed sensitive? It seems like if i have them on intermediate at a low setting and i increase my speed the wipers automatically speed up and vise versa when i slow down
RaineMan Jul 23, 2006 02:51 PM
Yes... the wipers are somewhat speed sensitive...
they will increase speed by one setting when you go 50MPH or over. Try it next time it rains... put the wipers on the fastest delay setting... then creep up to 50MPH and watch them switch to constant low setting. It's a really nice feature... you don't have to constantly switch them up and down when you stop at a light.
TheToolmaker Jul 23, 2006 03:06 PM
My car does the same thing!!!
About a month ago my car started doing exactly what you described!!!:cussing: If you push the stalk up towards high without actually clicking over to high my low speed will usually start to work. I am gonna take mine to the dealer so they can install a new switch.......
05BlackCobaltSS Jul 23, 2006 03:09 PM
are you sure that the "high intermintent" speed is the same as the "low" speed? This is what I thought was the case. Try going from "low intermintent" to "Low" and see if anything happens.
Cirrus Jul 23, 2006 03:17 PM
Same issue started around last month on my car, too.. Will be into the dealer shortly..
TheToolmaker Jul 23, 2006 03:18 PM
yep I am sure.... if its on low intermittent and you click it to low speed it stays on intermittent....
06G5GT Jul 23, 2006 03:27 PM
There is only one notch for intermittent and then you use the band to adjust the interval speed.
It goes - off, intermittent, low and high.
joeytroy Jul 26, 2006 10:25 AM
Also remeber that the wipers have a built in function to shut off if the motor gets to hot. It's all in the manual.
xl1200r Jul 26, 2006 10:31 AM
I've found that they actually have 2 speeds that they change. When set on the fastest inetermitant setting, I find that they speed up a little at 40mph, and then go constant (same as normal "low" setting) at 50mph like you described. I thought I was going insane and the switch was bad until I realized it always changed at the same speeds.
