Leaking hose
05 SS. Drove the car this morning. Went to move it, to get another car. Saw a puddle under the car. Looked under the hood, saw this leak. I've checked the clamp and it is just a tad loose. If I need to replace the hose, does anyone know the specific name of the hose?
https://cimg8.ibsrv.net/gimg/www.cob...41a431bc7c.jpg Just incase you guys don't see it, it's the hose right by the cooling fan. |
just tighten that somebitch. looks like its still in good shape
Originally Posted by tomj77
(Post 7706375)
I added coolant to the coolant reservoir. Is the coolant reservoir filled too much? Would over filling cause it to leak? The car leaks from the coolant reservoir when running.
https://cimg5.ibsrv.net/gimg/www.cob...9aa2188456.jpg |
Thats the engine coolant bottle. The leak you were pointing out was on the supercharger cooling system. |
(Post 7706445)
Yes, the engine coolant reservoir appears to be overfilled. When the engine is cold the coolant level should be at the seam of the tank where the cold fill level label and arrow is.
https://cimg6.ibsrv.net/gimg/www.cob...5b2e6a1d99.jpg |
Originally Posted by LsCobalt07
(Post 7706447)
