Lnf excessive oil blow by.
Hey guys, as a title says I have a problem with my PCV sistem( I think). To make a long story short I will post a link from hhr site. So if anyone know what is going on, or had the same problems, the help will be hugely appreciated. Thanks. https://www.chevyhhr.net/forums/gene...exhaust-61037/
could be turbo seals, bad pcv valve in intake, bad valve seals, rings. do a compression test, check intake and pipes for oil, change pcv valve.
also leak down test
