LOUD squeaking in rain
Whenever it rains out and i drive somewhere nd let it sit for a while when its rainin, it always makes these high pitched squeaking sounds. Its terrible and soooo loud. It does it a couple times and after i get on the road it stops. Anyone have this problem?
is it only when you brake?
Originally Posted by fballman1987
(Post 2423767)
i get a tick tick tick tick when i apply the brakes at a certian position...worn down break pads or rotors?
mine does it too, its from sitting the brakes will squeal.. itll go away once the brake surface has been taken off(you use the brakes for an extended period of time)
(Post 2423788)
Mine does this as well, and it pisses me off. If it was just a bit of a squeak, it wouldn't be so bad. But, its just so damn loud...
Originally Posted by Projekt
(Post 2423798)
mine???
My rear brakes squeal when i go in reverse if they are wet and I had the parking brake set. I think it's a cobalt thing =/
whats the tick tick tick thing???
(Post 2423836)
(Post 2423836)
if its a squeaking noise it could be water splashing up on the belt making it slip a little, my truck used to do that all the time only in the rain. haven't had my 'balt in the rain though and don't plan on it haha
Originally Posted by REIGN SS
(Post 2423892)
Do you feel any pulsation in the pedal? Is this all the time, only during hard braking, wet pads?
Our rotors rust at the hint of moisture , i wash my car and by the time i dry it off and back it out of the driveway , the rotors are squealling like a pig.
(Post 2423892)
