LSJ oil filter houseing, what goes here?
Old 07-14-2017, 08:20 PM
jdbaugh1's Avatar
Went to start up my freshly built engine for the first time and I started spraying oil out. My L61 block doesn't have anything here so I didn't think anything of it. What goes in this location on the filter housing? I need to plug it.
I need to plug this but I don't know what normally goes here on an lsj block.
Old 07-14-2017, 09:03 PM
jdbaugh1's Avatar
Nobody would happen to have the measurements (Inside diameter and outside diameter) for the O-ring in the photo below would they. Or alternatively know of a block off plate you can buy?
I figured out it is this oil cooler is what would go there.
Old 07-14-2017, 09:06 PM
jdbaugh1's Avatar
Or does oil have to flow from one hole to another?
Old 07-14-2017, 10:16 PM
Oil flows from one to another. So contact Mr.B and see if he has a lsj oil cooler flange that has AN bungs so you can just run a loop. Or find an lsj oil cooler and connect it
Old 07-14-2017, 10:18 PM
Sharkey's Avatar
the oil cooler goes over that hole. oil must flow between those 2 holes, however you can remove the tube inside the hole closest to the bellhousing and then install a blockoff plate.
look up "ecotec oil cooler delete"
Old 07-14-2017, 10:58 PM
jdbaugh1's Avatar
Awesome thanks guys. How hard is the tube to get out?
Also, the oil cooler is just a heat exchanger right? So I can just bolt it up and leave the water hoses disconnected can't I?
Old 07-15-2017, 12:30 AM
Sharkey's Avatar
yea you can. but at that point, you could change the thermostat housing as well and have the benefits of having an oil cooler
Old 07-15-2017, 08:27 AM
jdbaugh1's Avatar
Oh I didn't realize it tied into the engine coolant. You know what other parts I would need?
Old 07-15-2017, 01:49 PM
jdbaugh1's Avatar
Getting an oil cooler and all the lines from the t-stat housing up plus bolts from mongo.
