No supercharger coolant.
Old 10-13-2012, 12:49 PM
Andrewjw09's Avatar
So, I just got my car like 2 months ago. Never really bothered checking the coolant on the s/c til now... apparently there is none running through it. It's as dry as your grandmother's vagina. And one of the cables (the one on the top) is not hooked up to anything. Is that normal? lol
And could there be damage if I've been running it dry the past couple months? =/
Old 10-13-2012, 12:52 PM
nhanson's Avatar
Might be bad for the pump. Get some water in there and see if it circulates. If it doesnt then you have a bad pump.
Can you get a picture of the top cable deal youre talking about?
Old 10-13-2012, 12:55 PM
bluebalt07's Avatar
^this. That coolant runs through the manifold to cool the air down after the sc, no coolant means hot air so it's probably way down on power.
Old 10-13-2012, 12:57 PM
ionREDLINEracer's Avatar
There should be a hose at the top of the filler neck that is only a couple inches long that leads to nothing. Thats normal, it acts as a bleeder/run-off, kind of.
Edit: Here is a picture of what I was talking about. Is this what you were talking about?
Old 10-13-2012, 12:58 PM
def need pics
nhanson's Avatar
A little explanation so you understand.
S/C creates a lot of heat. The cores in the intake manifold have water circulating through them (yours is empty). When it gets too hot the computer takes away timing due to the temp and/or knock retard showing up.
+1 yea thats for overflow or something
Old 10-13-2012, 01:05 PM
Andrewjw09's Avatar
I got pics now, how do I upload them?
Old 10-13-2012, 01:12 PM
bluebalt07's Avatar
Click on gallery up top, then upload which will be on the right under your name, then browse to find the pics you want, select a category and click submit. Then to post in here, click on post reply, then the 5th icon from the left right above where you type will say insert image, copy the direct link from your pic after it is uploaded and paste in that box. Best to have 2 tabs open to do that
Old 10-13-2012, 01:13 PM
Andrewjw09's Avatar
Yeah, that's it.
Old 10-13-2012, 01:15 PM
bluebalt07's Avatar
Then you don't have to worry about that one. Just add some coolant or water to see if the pump is working. If it isn't, hit it with a hammer to kinda kick start it which might make it last for a little bit but you will end up having to buy a new pump
Old 10-13-2012, 01:21 PM
Andrewjw09's Avatar
Oh, you guys are going to get a ******* kick out of this. Keep in mind, this car was pre-owned by a woman. I can tell by the rim damage. Anyways... Like I said... Dryer than ****.
Old 10-13-2012, 01:22 PM
Andrewjw09's Avatar
Did one with flash on, one without... was trying to make it focus on the bottom, where you can see like... small pieces of what looks like wood chips... idk
Old 10-13-2012, 01:26 PM
rukkee's Avatar
That coolant had to go somewhere ...... might have a leak in the system. I havent heard of one that got hot enough to push the coolant out of the overflow but i guess its possible.
EDIT: WOW...... I cant even imagine what caused that. damn
Old 10-13-2012, 01:28 PM
Andrewjw09's Avatar
What do I even do with this? There's literally solid chunks of stuff down in there.
bluebalt07's Avatar
I'd definitely clean that out before filling it back up
Old 10-13-2012, 01:34 PM
Andrewjw09's Avatar
Any chance of damage to the supercharger from running it dry like this for.... couple months or god knows how long.
Old 10-13-2012, 01:38 PM
rukkee's Avatar
I would try and flush it ...... but I remember people had trouble getting the air our of the stock setup ..... or if the heat exchanger is full of **** you might want to find someone selling their old stocker or upgrade it with an aftermarket piece.
I remember the M62 setup GM had for the cavalier didnt have an intercooler so I think the blower can survive it but prolly not good for it 8). I would do an oil change on it if it was me.
Old 10-13-2012, 01:51 PM
klotzy_550's Avatar
Coolant makes "crusties" like that normally when it dries up, pour a little water into the cap and see if it dissolves the crusties. If it does fill up your system and find that probable leak. If it doesn't you could pull off the intake and heat exchanger goodies and flush it all. Just my .02$ I've seen that crusty stuff before in my mopeds cooling system and if I recall correctly it dissolved in water. Definatly get it figured out its no good driving it when the engine is half retarded.
Old 10-13-2012, 01:54 PM
Andrewjw09's Avatar
I'm already buying the ZZP S3 HE. So there's that...
And I just had an oil change done like two weeks ago. I thought they were supposed to check all the fluids when they do an oil change. Apparently not...
Old 10-13-2012, 01:55 PM
Andrewjw09's Avatar
Thanks, I'll see if it dissolves.
Old 10-13-2012, 02:02 PM
1LowLS's Avatar
They don't check the oil in the SC. your SC is fine being ran with no coolant.The coolant only runs through the intake manifold,not the supercharger.Fill it up,look for leaks,and make sure the pump still works.The pumps tend to burn up being ran dry.
Old 10-13-2012, 02:08 PM
rukkee's Avatar
Yeah.... I was talking about the SC oil..... If your worried about it or the car has high milege ...it might be worth changing . I'm not sure the change in operating temp is enough to effect the blower but I'm over cautious with my cars.
Old 10-13-2012, 02:33 PM
1LowLS's Avatar
The Jbody M62 kits are unintercooled so it's fine being ran dry.Only the IAT's go up.
Old 10-13-2012, 02:37 PM
bluebalt07's Avatar
Running no coolant won't affect the blower at all. It will run at the same temp intercooled or not. It's the air being pumped through the intake manifold that will have the difference. Non intercooled it will just be hot and kill performance but as long as you don't go trying to do WOT pulls with the IC system dry, you won't have any problems arise from this
Quick Reply: No supercharger coolant.
