Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Problems/Service/Maintenance (https://www.cobaltss.net/forums/problems-service-maintenance-69/)
-   -   Not enough boost! (https://www.cobaltss.net/forums/problems-service-maintenance-69/not-enough-boost-318464/)
volsfan92 Jul 26, 2015 06:51 PM
Not enough boost!
So I hooked up a new mechanical guage and it's only hitting 14-15 psi.. On the stock guage I was getting 17-18psi.. I tapped into the line coming from top of mani for boost.. Pretty sure I have a vacuum leak around the manifold gasket.. Will this cause low boost readout on the new gauge?
Sharkey Jul 26, 2015 07:43 PM
what pulley are you running?
Sl0wbaltSS Jul 26, 2015 07:56 PM
Or maybe they both read differently.
volsfan92 Jul 26, 2015 08:02 PM
It's a 2.6 and it doesn't seem like it should be that far off
volsfan92 Jul 26, 2015 08:48 PM
Could it be that the mechanical is more accurate?
SSfamilywagon Jul 27, 2015 12:40 AM
14-15 psi is really low on a 2.6 unless you'd have ported head ,cams and free flowing exhaust.
I'd double check your connection at the source and the back of gauge itself.
Sharkey Jul 27, 2015 01:31 AM
what brand of gauge is it?
mrbelvedere Jul 27, 2015 12:02 PM
air temp and altitude can be part of it bad bypass actuator also
volsfan92 Jul 27, 2015 12:49 PM
I've checked all the lines.. I bought some good line instead of the clear shit and it's the glowshift gauge I've got friends that use it with no issues
SSfamilywagon Jul 27, 2015 05:02 PM
If you trust the gauge and your install then you need to check your by pass valve. Probably not closing all the way and bleeding boost
volsfan92 Jul 27, 2015 11:11 PM
Thats the black thing on top of sc correct?? Also how could I check it
volsfan92 Jul 28, 2015 12:41 PM
The valve moves easily on the bypass interceptor reads 16-17 on manifold psi
